gx piston
Old Jan 1, 2010 | 02:33 PM
j0keefe21's Avatar
Default gx piston
looking to buy a set of gx pistons... anyone know of a good place to get them from? thanks
Old Jan 1, 2010 | 05:00 PM
thumper64's Avatar
Default Re: gx piston
assuming you're looking to up compression in a D15B? Look at D16A6 pistons or other older D16 pistons. They had a higher comp. height and will increase compression. They're cheaper also, Honda wants like $80 a piece for the GX pistons...
I went down that road before and decided for the amount it costs versus the gain, I may as well go B series. Go total out a decent header, pistons, cams, valve train and look at a B20 swap...
Old Jan 1, 2010 | 09:09 PM
Jackal6042's Avatar
I know the P08 pistons in the D15B and the PMS pistons in the GX are shorter in height. Are D16A6 pistons the same? I know you can't use like D16Z6 pistons in a D15B because of this. Not sure on the A6 pistons though.
Angel4768
Oct 20, 2011 10:57 PM
Ryan#1
Oct 2, 2008 06:27 PM
Hy-wind
Dec 2, 2004 04:18 AM
b20ek
Apr 18, 2003 02:37 PM
blkDOHCsol
Mar 24, 2002 01:30 AM
