Prelude Backseat
Hey i just got a 92 prelude s im wondering how you can take out the whole backseat ive researched and nothing really seems to help and takes way to long to sort through
Thanks
Thanks
There's 2 clips under each bottom part that you pull on, and lift the seat bottoms up. It usually helps to push the seat down while you're unclipping it, then pull up.
Then there's a bunch of 10mm bolts scattered around.. some are exposed, some might be covered by the plastic panels.. can't remember. But it's pretty easy to tell where they're going to be, by where the seat is stuck still.
Not hard.
Not hard.
