Full Race, Honda OEM, Golden Eagle, Garrett, BMPC and More
* Burns Stainless 2" exhaust canister SM-200-350-12 $150.00 (WEIGHS 2 POUNDS)
* Vibrant 4" to 3.5" 3" long black coupler $20.00
* ETS 4" ID 90* blue coupler $20.00
* 4" ID straight 3" long black coupler $15.00
* Clampco 4" - 4.5" t-bolt clamps $20.00 (Four 4 OF THEM)
* Aeromotive 11101 A1000 external fuel pump $180.00
* AEM 0 - 100 PSI oil/fuel pressure gauge with sensor $105.00
* Billet Specialties 1/4" double line holder $8.00 (TWO 2 OF THEM)
* Vishay Dale 1.5k 50watt wirewound resistors $8.00 (SIX 6 OF THEM)
* Stewart Warner Performance Ultra Shift Light 94DSWP $25.00
* Full Race T4 44mm B series thermal coated ramhorm $400.00
* Garrett T6 466707 - 5002 .60 a/r compressor 1.08 turbine journal bearing turbo $400.00
* BMPC R1833 intercooler $190.00/EACH (TWO 2 OF THEM; GOOD FOR 500WHP ON GASOLINE)
* -10 stainless an fitting heat shielded flange return line $15.00
* K&N 3" ID turbo filter $8.00
* GT series red anodized water line fittings $6.00 (TWO 2 OF THEM)
* Golden Eagle Mfg LS/VTEC conversion kit $50.00 (NO HEAD STUDS NO HEAD GASKET)
* Honda OBD-II engine harness $80.00 (MISSING INJECTOR CLIPS)
* Honda 2000 LS NON VTEC pistons and rods $45.00 (39,000 MILES)
* Hondata intake manifold gasket LS NON VTEC $15.00
* Honda P75 ecu $20.00 (NO COVER I THINK THROWS PGMFI CODE; CAN BE FIXED)
* Honda LS NON VTEC rocker arms $120.00 (BRAND NEW)
* Honda 2000 Civic Si fuel rail $8.00
* B series red bored fuel rail $10.00
* Honda ITR 14111-P73-J00 intake camshaft $120.00 SOLD
* B series into EK shift linkages $15.00 (BOTH)
* B series throwout bearing $15.00
* B series coil $5.00 (UNKNOWN IF WORKING OR NOT)
* B series OBD-I distributor WITHOUT coil and cap $35.00 (P30B D02693 ON INSIDE)
* B series OBD-I distributor WITH MSD Pro Cap 8292 $40.00 (WIRED FOR EXTERNAL COIL)
* B series OBD-I distributor WITHOUT coil and cap $40.00 (PR4 D02754 ON INSIDE)
* B series distributor cap $15.00 (TWO 2 OF THEM)
* B series throttle body with tps and map sensor $20.00
* Portflow, Ferrea or Supertech dual valve springs and titanium retainers for B series $150.00 SOLD
* 2.5" aluminum u-bends $40.00 (FOUR 4 OF THEM) SOLD
alpha
Jan 12, 2010 03:30 PM
alpha
Dec 18, 2008 08:01 PM
kaj
Jul 3, 2006 01:38 PM
kaj
Mar 17, 2006 12:40 AM
SIMSSEGA
Mar 15, 2006 06:41 PM
