Timing belt questions
Old Dec 31, 2009 | 11:54 PM
journeyquest's Avatar
Default Timing belt questions
Im getting ready to replace my timing belt on my 90 crx dx. 1.5 liter. I have belt, tensioner, water pump, crank and cam seals. Do i have to remove the valve cover for this job? Does the water pump o ring go on dry? Do you use locktight on the crank bolt? Will it cause a problem if i leave the upper timing belt cover off? Thanks
Old Jan 1, 2010 | 08:02 AM
StylEmon's Avatar
Default Re: Timing belt questions
Check the manual for valve cover removal.
Water pump o-ring goes on dry.
I didn't use locktight on the crank bolt, but to get mine off, I had to use an extension and a sledge hammer...
The first two pics are tools that broke, or didn't work
http://91civicwagon.blogspot.com/200...air-day-2.html
Yes it will cause a problem if you leave the upper cover off. Dust and grime and crap will get in there from your other belts.
91 b20 integra
Sep 22, 2014 08:44 AM
cstap
Oct 7, 2013 05:00 PM
supracrx
Feb 17, 2008 09:06 AM
89hbcivicguy
Mar 18, 2005 07:44 PM
242 Accords
Nov 22, 2004 10:52 PM
