car bogging on low rpms?????
so recently ive been driving my 95 gsr stock no internal work done to it......and its been running crappy like if it has a bad spark plug wire but i checked em and there good also there is a lil of water and oil inside the one of the spark plug wire where it plugs to the spark plug i cleaned it up and dried it and today again it manages to get soaked again...i also put silicone on the valve cover seals to seal perfect and sum how it still gets oil....
cliff notes
-oil or water like substance gets on one spark plug wire and boggs on every low rpm on each gear.. lmk what it can be........thnxxx and happy new year...
cliff notes
On the leak problem. I would just buy a new vavle cover gasket kit and put everything new under there. Clean it and dry it very well. Honda bond it back up and it should do the trick. Make sure you snug the bolts. As for the bogging issue. Is there a Check Engine Light on? Does the light even work? Sometimes it could be few different sensors. But they would most likely throw codes.
A VC leak shouldn't cause a performance loss. I'd do a compression test to see how you are doing. A new VC gasket also wouldn't be a bad idea, because that's the best way to fix a VC leak (plus they are super duper cheap -- not like a head gasket at all).
had the same problem on my db7. Fixed everything i could imagine would be the problem from spark plugs, o rings, gaskets, fuel filter, plugs, etc.
Still could not find the culprit after 500 bucks into it so i got rid of the car.
Is there any weird smells coming from the engine bay?
