Replacement for the Master Cylinder
Old Sep 3, 2002 | 05:24 PM
The Punisher's Avatar
Default Replacement for the Master Cylinder
Is there a replacement Master Cylinder for an ABS 4th gen VTEC? I need one that is smaller than stock, or has the connections for the hard line on the underside of the MC. I had considered blocking off the ports for the hard, and having the stock one drilled and tapped underneath, but I don't know if this is a very good option.
If you want to know why I need this, I have a Golden Eagle intake manifold and it is bending my front brake line straight down. You can't fit a piece of paper in between the manifold and the the brake line. Thanks in advance.
Old Sep 3, 2002 | 07:01 PM
ryanstev's Avatar
Default Re: Replacement for the Master Cylinder (gsr*lude)
If you use a different size master cylinder, you'll need to get new wheel cylinders as well.
Wilka
Suspension & Brakes
Jan 21, 2013 06:53 AM
wubanga
Feb 13, 2012 07:12 AM
cpthaegdon
Jul 20, 2011 11:12 PM
alscrx
May 9, 2008 04:34 PM
