Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
question about wheel size!!!!
Old Dec 30, 2009 | 10:04 PM
thinhkaka66's Avatar
Default question about wheel size!!!!
hey guys i have a honda civic coupe 09 EX. my wheel size is 16 in, but i wanna buy and replace it with 17 inch wheel. is it okie? does the size of wheel matter?
Old Dec 30, 2009 | 10:08 PM
h2bek's Avatar
Default Re: question about wheel size!!!!
yeah 17"s on that car will be ok as long as u dont put like 20"s on it.remember the bigger the wheel the more rotation mass thus makin you car slower
Old Dec 30, 2009 | 10:19 PM
so u mean that my car would run slower after i put 17'' wheel in right? any suggestion to prevent it?
Old Dec 30, 2009 | 10:41 PM
vladd's Avatar
get a 17" wheel that weighs less than your stock 16" wheel. don't forget to include tire weight when calculating the weight of the new wheels.
Old Dec 31, 2009 | 12:24 AM
i-VTEC_DOHC's Avatar
going from oem 16 inch ex wheels to any 17" aftermarket wheel is going to be lighter unless you get one of those ugly chrome wheels.
Old Dec 31, 2009 | 04:58 AM
TrueIce's Avatar
Makes sense..
Old Jan 3, 2010 | 03:06 AM
Kidnkorner's Avatar
The tire is the heaviest part of the wheel/tire combo, the further you push this weight away from the center axis the more performance is negatively affected.
Old Jan 3, 2010 | 03:44 AM
pi Ka chuuu's Avatar
it is true that when a wheel is bigger it takes longer to make a full rotation and that will cause your car to be slower and it can also throw off your MPH gauge making it inaccurate. but in your case a 1 inch difference wont cause much change or atleast anything noticable. an easy way to keep everything normal and to give u less worries is to buy a tire with a smaller profile if you are going to buy a bigger wheel. try to make your wheel+tire diameter equal to your previous 16 inch set up and everything will remain pretty much the same.
Old Jan 3, 2010 | 07:02 AM
jamin's Avatar
last post is good.
changing wheel size should affect your speedometer accuracy.
why bother for a 1 inch look. oh, but it is good for the economy.
nonvtecD
14
Apr 22, 2004 09:55 AM
silver_nteg
Jan 6, 2004 11:02 AM
TypeR 01 886
Oct 23, 2003 06:32 PM
RebelleadeR
Mar 1, 2003 12:13 AM
non-VTEC
Mar 17, 2002 09:24 PM
