Need Greddy E-manage ultimate software!!!
Old Dec 30, 2009 | 05:29 PM
stradbally's Avatar
New User
Default Need Greddy E-manage ultimate software!!!
Hi - I bought a 2006 Civic SI with the Greddy Turbo kit and e-Manage Ultimate engine management system installed. It runs, but did not come with software, so I can't tune it. Other than the turbo kit, it has a cat-back exhaust system and no other modifications, so it's pretty much exactly what Greddy originally designed the kit around.
I would like:
1) A copy of the original PC software used to connect a PC to the e-Manage system. Does anyone have a link to an .ISO or .ZIP file, or can email it to me?
2) A base map of all the settings that someone has found works well for a starting point. Every car is a bit different, and I am comfortable adjusting the tuning (have used EFI, Electromotive TEC, Holley Pro-Jection, Apex'i PFC and other EMSs in the past), but really don't want to start from scratch.
Any help/advice is sincerely appreciated!
Last edited by stradbally; Dec 30, 2009 at 06:36 PM. Reason: had new info to add...
Old Dec 30, 2009 | 06:47 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Need Greddy E-manage ultimate software!!!
here you go. not sure if this is what you are looking for.. but good luck.
Old Dec 30, 2009 | 07:47 PM
stradbally's Avatar
New User
Hi - thanks for the link.
1) The Ultimate220.exe seems to be the firmware update for the unit. I actually need the software for the PC itself. Any ideas?
2) Also - I dl'ed a version of the e-Manage PC software from the mitsubishi site, just to see if I could connect -- here is the link:
http://www.3si.org/forum/f103/need-d...d-help-326470/
This allowed me to connect to the car, download the settings and be able to view/save them from the e-Manage. However, I receive an error message that states, "ONLINE, communicate with e-management in real time" -- the two options from the alert window (OK and Cancel) do the same thing: nothing. the error window pops up again within a few tenths of a second. I searched google and found that someone else had had the same error message and problem, but it doesn't appear they ever found a resolution (or posted one): http://www.scionlife.com/forums/showthread.php?t=155907
Has anyone had, and resolved, this "ONLINE, communicate with e-management in real time" issue? What was the fix? (I acknowlege that using the downloaded e-Manage software from this site may be causing the issue, so I would love to get a copy of the PC software that someone else is using successfully on their 2006 Civic SI).
Many thanks!!
Old Dec 31, 2009 | 11:40 AM
Race_RPM's Avatar
The issues are related. You've got a mismatch between the eManage ultimate firmware (on the ECU) and on your PC/laptop. To resolve, start with a clean PC reboot, download the Ultimate220.exe file to which you were referred, install that using the default options (keep clicking Next). Start the eManage PC software, connect the cable to the car, and it will ask you if you would like to update the ECU. Proceed. Then you'll match the software and ECU and should have no more issues.
Good link for the laptop/PC software!
Old Jan 1, 2010 | 11:30 AM
stradbally's Avatar
New User
Thanks! That worked perfectly!
Does anyone have a baseline map (*.EM2 file from their PC/laptop) they can share for the 2006 Civic SI with the Greddy Turbo kit? I recognize this will probably need more tuning, but would get the car started and running correctly. It appears my eManage Ultimate doesn't have a baseline setting configured.
Thanks again and happy 2010!!
Old Jan 9, 2010 | 07:31 PM
Race_RPM's Avatar
Sure. Check it out the Greddy eManage Ultimate map repository here:
http://www.*************/forums/turb...-has-best.html
Old May 3, 2014 | 03:23 PM
shippy's Avatar
to all you guys struggling like I did to get this kit working
download the ultimate220.exe or ultimate230.exe and follow prompts to install
open file location and locate driver folder
you will find preinstall in this folder
this will install the usb driver needed
emu will only run on 32bit pc's up to and including win7
xp64bit will not work
win7 64bit will not work
it nearly works on the 64bit pc's lol
it is a b1tch to install and may not work first time if you have issues uninstall and restart pc
then start again and again...
redliner8000
Mar 22, 2005 06:44 AM
dabrown
Jun 19, 2004 10:14 PM
mister2racer
Oct 18, 2003 09:36 AM
FredoSP
Jan 30, 2003 12:45 AM
