d16y8 ek!!!
im currently building a d16y8 with the following items listed below,but now i dont know what ecu to use! what do you guys suggest??and how many hp do you guys think ill get out of it...?? im stuck just cause of ecu????
d16y8
vitara pistons
eagle rods
crower valve springs
crower retainers
crower vavles
crower stage 2 cam
acl bearings
arp headbolts
head work and 3 angle valve job
cometic head gasket
golden eagle block guard(how can i forget that)
aem cam gear
aem fuel rail
aem fuel filter
walbro 255 fuel pump and fuel cell e85
b&m fuel regulator (thinking of getting aem though)?
skunk2 pro intake manifold
hondata intake manifold gasket
skunk2 throttle body 70mm
rc 750 injectors
moroso oil pan
garret gt30r turbo
tial bov
tial wastegate
ram turbo manifold
gates racing timming belt
gates racing serpentine belt
blox map sensor block of valve
speedfactory 4bar map sensor
greedy boost controller
apexi turbo timer
and i currently have a new afc neo??but dont know whether to use that or go hondata??? this is where i need help...
d16y8
vitara pistons
eagle rods
crower retainers
crower vavles
crower stage 2 cam
acl bearings
arp headbolts
cometic head gasket
aem cam gear
aem fuel rail
aem fuel filter
rc 750 injectors
moroso oil pan
garret gt30r turbo
tial bov
tial wastegate
ram turbo manifold
apexi turbo timer
I'd say before you build it get block posts. I'm running a stock sleeve bored .20over and regret not doing this before I put it together. I guess I'll see how far I can push it with the setup I have soon.Oh well too late now, but if I could do it again I would have put in block posts to save myself some possible headache.
That right there in mo is the BEST advice given so far. We can tell you the ecu's that we like and love tuning with but not all tuners are the same. You will be putting ALOT of trust into your tuner why not let him pick what he or she is most comfortable with. BTW great parts list for the build good luck.
im really taking this into consideration...thanx im thinking of driving the car up to central florida turbo to get it tuned on hondata i heard thats their specialty..
