2000 accord lx v6 starts then stalls right away
Old Dec 30, 2009 | 03:55 PM
gen2tegboi's Avatar
Default 2000 accord lx v6 starts then stalls right away
Hi H-T,
I have a 00 v6 Lx Automatic. The car was driving fine until I tried starting the car at the mall, the car would start but in a split second the car would stall. I tried again but stepped on the gas right away to keep it revved then quickly put in drive and it worked, it idle perfect. it drives perfectly fine after I do that even at lights when car is stopped.
The check engine light came on, and the codes were; P0301, P0304, P0405, P0300, and p1399. All pretty much misfires. the codes were cleared, check engine light didn't come back but problem is still there when we start it.
I am starting to think it could be the IAC valve or the FITV because it only happens at start up, and the revving and putting in drive remedies it. Does anybody else have any experience with this?
This is my Girlfriend's DD and we need to fix this asap, we appreciate any help troubleshooting this problem.
Old Dec 30, 2009 | 04:04 PM
mohadib's Avatar
Default Re: 2000 accord lx v6 starts then stalls right away
i would clean the IAV and throttle body.
Old Dec 30, 2009 | 04:37 PM
gen2tegboi's Avatar
That is what I will be doing once I'm out of work (tomorrow afternoon), do you know where it is located in this engine? lx v6.
Old Dec 30, 2009 | 04:42 PM
mohadib's Avatar
if you remove the air hose to the throttle body, and look in the throttle body, you should see a little hole. Thats where air goes into the IAC. On the outside of the TB on the same side with the whole, you should see a sensor looking thing screwed on. Thats the IAC. Should have a couple of screws holding it in place iirc.
Old Dec 31, 2009 | 08:17 AM
gen2tegboi's Avatar
Bump....for some advice im stuck here.
Revenelson
Feb 25, 2015 12:54 AM
MTapester
Apr 1, 2011 11:41 AM
wwelopez
Jan 10, 2010 12:36 PM
AGaz01accord
Jun 13, 2009 10:46 AM
pumafeet10
Apr 29, 2008 06:21 PM
