A question about vtec engagement and d series redline...
Old Dec 30, 2009 | 03:21 PM
fryman's Avatar
Icon2 A question about vtec engagement and d series redline...
I noticed that on my sisters civic with a d16z6 and auto tranny it will shift gears at 5000 rpm max but vtec is supposed to kick in around 5k rpm so I was wondering whats with that and also I usually shift my D15B vtec at 7000 rpm max to get the full effect of vtec but since Honda made the auto tranny switch at 5k max does that mean its bad to let the rpm's get higher than that even though redline is 7200 rpm?
Old Dec 30, 2009 | 03:27 PM
SimpleAznMan's Avatar
Default Re: A question about vtec engagement and d series redline...
Its rare for your to get full potential out of the car with an automatic transmission... since it controls when to shift. Just like my Corolla S, VVTI doesn't start until I believe 5k RPM as well, but with it being automatic... it shifts at 4.5k RPM.
You could run it in D3 or overdrive so that the transmission stays in 3rd gear, that way you can get it up to VTEC RPM's for it to kick in.
Cheers.
Old Dec 30, 2009 | 04:22 PM
Linked's Avatar
if your going WOT (which is the only time vtec kicks in), automatic transmissions go all the way to the redline before shifting, or atleast their suppose to
Old Dec 30, 2009 | 04:25 PM
thumper64's Avatar
Manually control the auto using switches to open and close the shift solenoids. You'll probably blow it up, but who cares?
Old Dec 30, 2009 | 04:37 PM
BrayzieEF9's Avatar
Haha never let a speed junkie drive auto wit a sport button they'll blow your tranny haha
Old Dec 30, 2009 | 10:52 PM
fryman's Avatar
Hmm ok thanks for the information everyone...its just something I always wondered about.
I'll try her car with WOT when I get a chance and see what happens.
Old Dec 31, 2009 | 06:14 AM
rick_rabies's Avatar
I'm not Rick!
^your d15b can take sum abuse. chip the ecu and go to 7500. i had a d15b and beat the mess out of it.
Old Dec 31, 2009 | 08:51 AM
92ehatch's Avatar
there is no reason for vtec unless you are WOT anyways.
if you are just cruising around whats the point in revving it past 4-5k anyways?
Old Dec 31, 2009 | 10:29 AM
mikej94civex's Avatar
d16z6 and d15b have the same redlins (7,200) but vtec is different...
the z6 crosses over at 4,800 and the d15b at 5,600, also shifting at 7k will most likely
put u a little out of the powerband if not completely out of it by a few hundred rpms.
and like the other guys said auto tranny destroy performance and they have sensors to
tell them to shift.
if u wanna know the stats on each of the two motors go to google and type 'honda d series'
and click the wikipedia link it will tell u all u need bro!
fryman
Sep 28, 2008 02:32 PM
nos4a2si
Sep 27, 2005 07:15 PM
jdm4dr
Aug 6, 2003 04:27 PM
S2KILLA
Jun 11, 2003 06:40 AM
sweetcivic
May 29, 2002 05:13 PM
