CLUTCH TROUBLE.. ALREADY TRIED A FEW THINGS
Old Dec 30, 2009 | 12:32 PM
hondaguyflozy's Avatar
Default CLUTCH TROUBLE.. ALREADY TRIED A FEW THINGS
Sup my fellow honda techers!..
Alright so let me break down.
I have a 1992 honda civic si hatch..
single cam zc v..
I recently replaced my clutch about a year ago.
Anyways about a week ago i was parked with my
car on.. I had it on neutral and all of sudden i felt my
clutch pedal sink to the bottom. so i pumped it and it
regrabed and everything was all good. 5 minutes later it
does it again. So i checked the cables and fluid.. it had
no fluid so i figured i just needed. it was leaking from
the front headers side (slave cylinder area)...
SO i went and bought some fluid. i added some and pumped
my clutch and no luck!> so i figured it was time for some bleeding?..
after two bottles of fluid and bleeding still no luck..
So me and my pops replaced the slave cylinder(where you bleed
the clutch from).. and still no luck.we took of the master cylinder and
checked it and its in working order!...
i know its not my clutch!. its been working perfectly with no
problems.. any suggestions?
Old Dec 30, 2009 | 12:34 PM
Default Re: CLUTCH TROUBLE.. ALREADY TRIED A FEW THINGS
also theres no visible leeks and when we bleed the clutch it doesnt lose
much fluid
Old Dec 30, 2009 | 01:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
look down near where the pedal goes through the firewall, if it is taking fluid it has to be goin somewhere, or the master is done too and not building pressure.
Technot
Mar 18, 2018 12:55 AM
jdmstyleg
11
Sep 27, 2009 06:16 PM
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
Gomdohree
Apr 24, 2008 06:20 AM
Lb1atx
Sep 7, 2007 05:16 AM
