H22 auto-manual tensioner conversion help
Old Dec 30, 2009 | 10:31 AM
H2B-EK4's Avatar
Default H22 auto-manual tensioner conversion help
hi
i know this may have been covered before, here is the link to the thread which discuuses this.https://honda-tech.com/forums/showth...remove&page=10
im doing a auto-manual tensioner conversion on my h22a7, im using this guide http://www.collectiveracing.net/crfo...d34646680fc4ce
which balance shaft tensioner should i use my h22a7 one or do i need a h23 one? this is what they have said
"Next we will install the balance shaft tensioner pulley. For this install, we will re-use the H22 part. The H23 part has a larger spacer that places it further out away from the timing belt pulley. I recomend using the H23 part (not shown), but with a few washers (used as spacers) the H22 pulley (pictured) can be used correctly"
if i dont run the balance shaft belts but leave the BS in and gears on will i not need this bs tensioner on or will the bolt be too long then? ive read about using washers but is there any extact size and type of washers to use?
Another problem ive read about is the tri-pod piece which has a bolt which does not allow the tensioner bracket to move fully. here is a link to the thread which explains it better https://honda-tech.com/forums/showth......ove&page=10
i dont wanna take any risks leaving it out, anyone kept it and how?
thanks
Old Jan 1, 2010 | 06:13 AM
gibsanez's Avatar
Default Re: H22 auto-manual tensioner conversion help
I just left the belt off of my shafts and put everything back together when I did my tensioner conversion
blowngsr1
Feb 18, 2010 09:42 PM
lude98SH
Aug 11, 2007 10:59 AM
lude98SH
Jul 23, 2007 09:06 PM
prelude1911
Mar 5, 2006 04:00 PM
LudeyKrus
Feb 3, 2004 03:40 AM
