d16 Starter Wiring
Hey Guys,
Quick question:
Putting the engine back in the car. The starter has three terminals, one of which goes to the engine wiring harness. However, the other two , one goes to the starter itself and the second goes to the cable from the positive battery terminal, right? I dunno which goes on which terminal though. I attached a picture in which I have the starter cable on the back of one of the terminals, but I am not sure if that is right. Please help me out. Thanks!
Brian
Quick question:
Brian
The one coming from the battery should have a plastic cap on it, and the one coming off the harness has a female connector that connects to the male spade connector.
Well the cable from the positive terminal did not have a cap on it, but I do not like the idea of leaving it bare so I will get one for it... So does the battery cable go on the bolt on the right in the picture above?
From: I told you to wait in the truck in Texas, United States
The wire shown should go on the terminal to the right
then hook the battery cable to the terminal on the left..
You should have just removed the left side...
DarrenWB
Jul 1, 2019 05:28 AM
EVIL Hx Coupe
Mar 19, 2005 09:12 AM
