87 teg TB...will it work???
Old Sep 3, 2002 | 04:35 PM
zcivicz's Avatar
Default 87 teg TB...will it work???
i dropped by the local junkie today and i found an 87 teg with the brown top valve cover (if it matters) i was going to take the throttle body but i wasn't sure if it would fit on the A6 intake manifold cuz i need one for it and i can't an Si one around here. if anyone knows for sure that the 87 teg TB will work on the A6 IM and if the teg TPS will work with the Si ECU let me know ASAP! preferably before tomorrow so i can go back there and yank it!!!
[Modified by zcivicz, 1:36 AM 9/4/2002]
Old Sep 3, 2002 | 04:43 PM
zcivicz's Avatar
Default Re: 87 teg TB...will it work??? (zcivicz)
and oh yeah a local EF owner is trying to sell his 88 Si tranny with a 2 month old clutch, pressure plate, and resurfaced flywheel. would it work on the D15b2 block??? my car is a 91
Old Sep 3, 2002 | 05:25 PM
Mugen Dom's Avatar
itll fit a ZC i know for sure and teh si trans will fit ur car
Old Sep 3, 2002 | 05:32 PM
zcivicz's Avatar
Default Re: 87 teg TB...will it work??? (jdmb18hatch)
aren't the splines different between the 88 and 91 ??? so you aint sure if the TB will work, huh?? i looked at the TPS on the teg and its different from the Si, of course, but i think it would work if i take the plugs also...anyone else??
Old Sep 3, 2002 | 05:35 PM
Mugen Dom's Avatar
as long as u get the clutch pressure plate and flywheel u will be ok...btu u deff need it all to make it work...the TB is mostlikely teh same anyways the tps is the same but has a plug extention on it
Old Sep 3, 2002 | 06:40 PM
zcivicz's Avatar
TTT anyone else...by the way thanks for the replies bro!
Old Sep 3, 2002 | 07:05 PM
zcivicz's Avatar
and oh yeah what about the 87 CRX Si throttle body...would that work???
Old Sep 3, 2002 | 07:10 PM
Mugen Dom's Avatar
uhh do u just need teh TPS???
Old Sep 3, 2002 | 07:29 PM
zcivicz's Avatar
at first i just needed the TPS but now i need a TB w/TPS cuz i screwed up the linkage where the cable hooks on to. its the only thing now holding me back from starting my simple dx to Si head swap...
Old Sep 3, 2002 | 07:31 PM
Mugen Dom's Avatar
now that i think about it it may work take the intake manifold there with u and test fit it if they will let u...i think it will fit
Old Sep 4, 2002 | 06:32 AM
zcivicz's Avatar
**** dude i reinstalled the manifold to the head already but i did leave the TB off wouldn't that be easier ??? i just gotta make sure the holes match which they seem to be from what i can remember...
zcivicz's Avatar
and oh yeah what about my 91 axles will they go right in with no hassle into the 88 Si tranny ?????
Old Sep 4, 2002 | 06:54 AM
Mugen Dom's Avatar
yeh axles wil work fine
Old Sep 4, 2002 | 10:36 AM
zcivicz's Avatar
well just got back from the yard and got my 87 teg TB w/TPS for FREE! it was a near perfect match between the Si and the teg TB! i brought the Si TB in the yard with me and then i swapped it for the teg TB and walked out acting like i didn't find anything. now i just hope the TPS is working fine. the color on the wires are different though from my civic TPS plug. which one is which ???
Old Sep 4, 2002 | 10:42 AM
Mugen Dom's Avatar
just reverse the out wires from ur dx tps and plug it in ullbe fine
Old Sep 4, 2002 | 10:44 AM
zcivicz's Avatar
but theres three wires, i checked and which one am i supposed to reverse??
Old Sep 4, 2002 | 05:28 PM
4potnick's Avatar
I know this is kinda off topic but is the zc tranny the same as the first gen USDM teg trannys.
Old Sep 4, 2002 | 05:30 PM
Mugen Dom's Avatar
Default Re: 87 teg TB...will it work??? (4potnick)
no mount r diff
Wes90civic
Jun 17, 2006 02:39 PM
civicracer1993
Nov 7, 2003 06:35 PM
GroundZer0 336
Oct 9, 2003 11:54 PM
daniel89civ
Oct 10, 2002 08:35 AM
Red_Si
Aug 7, 2002 08:28 PM
