94 GSR tranny question
Ok im getting a B18 out of a 94 GSR and i already have mounts for a B swap as i planned on putting a B16 in my ef, but this deal came along and i snatched it. MY question is as follows, is the 94 GSR transmission hydro or cable. I have the cable mount currently. Also if it is hydro what ill do i have to get to make it work in my 90 EF std model.???? thanks much
I did but im getting a rebuild GSR with the transmission and fully wiring it up for 1350 so i had to pass on the B16 Y80 and go with the complete GSR. Where can i find this kit??
^stop yelling!
hasport is what i would recommend. it also happens to be nicely priced at the moment. it costs just as much to go the cheaper Ebay route.
hasport
http://hasport.com/store/index.php/efbhcl.html
eBay
http://cgi.ebay.com/ebaymotors/INNOV...Q5fAccessories
or go with eBay, but still buy hasport. save $8 and get free shipping
http://cgi.ebay.com/ebaymotors/HASPO...item5ad4b51412
hasport
eBay
hmm ok this seems simple enough, what am i to do about a reservoir for the fluid?? does anyoen happen to havea picture of the setup. Im just curious where **** goes and what not
personal preference and the best way imo...pickup a ys1 tranny. a broken one with good case or ls is perfect. internals from the hydro gsr drop into the ys1. you'll have to verify differential preload and mainshaft clearance. tranny will be cable actuated using hydro gsr gears.
ebay is kind of a last resort for me when i dont have enough money and i wana get my kar on the road soon...as far as the the cable to hydrualic...as far as i see on set ups..u dont need fluid becuase ur still using ur clutch cable....u just bolt the cable to hydrualic on th hydrualic tranny....but like the link d16si hatch has..u kan still get hasport on ebay...
Screw the different mounts and hydro conversion crap. Get a YS1 transmission case, then put the hydro gear set in there. I don't care what anyone says, this is the best way to solve the issue.
how am i suppose to come up with a Ys1 case. Seems alot harder then just getting the conversion kit. And i dont see the gains in going with the case versus just the kit. Its not out of my skill to do it. I have rebuild single and double counter-shaft transmissions.
You already have the mount kit for a cable transmission. if you sell it and buy a different mount then you will take a loss and have to buy another mount by its self, which is more expensive. You will also have the added expense of buying some type of hydraulic conversion. There are write-ups on this site that show how to completely disassemble transmissions, it's not bad.
http://cgi.ebay.com/ebaymotors/90-93...Q5fAccessories
http://www.orlandoforums.com/forum/s....php?p=1832462
There you go, the second one is a better price. Do it the right way.
