Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
RSX cluster swap problem
Old Dec 29, 2009 | 04:14 PM
Honda Rules's Avatar
Default RSX cluster swap problem
I have a 03 Civic EX, I got a 02-04 RSX cluster
So everything works except the radio(stock radio) or keyless entry, which is the security system I believe....
I follow this pin out and everything else works except the radio/keyless entry. The A3 Black/Yellow wire I do not have....the only wires left that wasnt use are..
Green/Black
Blue/Black
Black/Red
White
So there is nothing connected to A3 right now
Has anyone had this problem? I check the security fuse and it fine, I also switch another good fuse and it still dont work
Old Dec 29, 2009 | 05:22 PM
Harlowe's Avatar
Function>Fashion
Default Re: RSX cluster swap problem
Check the fusebox under the hood. There is a fuse labeled "Back Up" or something. That's probably blown. I had a similar problem when I did my cluster swap, as did a few other members.
Old Dec 29, 2009 | 05:27 PM
Ok, Ill check right now
Its sucks not having music to listen too while driving
Old Dec 29, 2009 | 05:43 PM
thanks Harlowe, I never would've check that
Its was blown and I replace it so everything works now
Old Dec 30, 2009 | 05:07 AM
Harlowe's Avatar
Function>Fashion
bmxkills
May 30, 2015 06:13 AM
93WhiteHatch
Apr 29, 2006 05:58 PM
TougeCoupe
May 18, 2005 05:12 PM
ithinkitsjdm
13
Feb 23, 2005 06:17 AM
SiR HatchAlot
Mar 28, 2004 09:31 AM
