HELP!!! 1990 Civic Sedan W/ 94 GSR
Old Dec 29, 2009 | 04:09 PM
mr.krits's Avatar
Icon6 HELP!!! 1990 Civic Sedan W/ 94 GSR
I recently put a GSR swap in my sedan and im having problems retrieving codes from the ecu. I spliced in the obd1 grey plug into my stock harness. I'm getting a check engine light now and are trying to retrieve the codes but when i ground out my service check connector wire it does nothing. i checked it for voltage and it has 5 volts thats the correct voltage it suppose to have. Another problem is that since i cant retrieve codes i cant figure out my other problems. It doesnt rev past 3000 rpm.
Old Dec 29, 2009 | 04:28 PM
thiendegigolo's Avatar
Default Re: HELP!!! 1990 Civic Sedan W/ 94 GSR
try checking to see if your tps sensor sensor is in its right spot..the two outer wire...how i figure out my check engine light problem was..i was able to get my friend that tune my car to plug up my ecu with a data log on it to his laptop and found the problem
Old Dec 29, 2009 | 04:40 PM
beansandrice's Avatar
Sounds like incorrect Distributor Wiring. I dont mean Firing order. Actual Wiring.
Did you wire it yourself?
Old Jan 1, 2010 | 04:45 PM
mr.krits's Avatar
yes i wired it up my self.
Nay
May 10, 2017 11:05 AM
footstinker
Sep 11, 2010 11:12 PM
slvrcvc93
Mar 20, 2009 01:46 PM
racingcrx
13
Sep 10, 2006 12:52 AM
LittleG112
Aug 17, 2003 10:24 AM
