car starts and then dies
my car it starts and shuts off right away i just put a new jdm b16 distributor and it started fine the first time but when i tryed to start it again enless i keep my foot on the gass and it smells like a lot of gass comeing out of the exhaust i have a b&n FPR and gauge it reads 60psi when i prime it how do i change the pressure and also why would my car be doing this is it a fuel problem???? any help would be appreciated thanx guys
does any one know what this could be? i got a new main relay so its not that can it be too much fuel to the car and it turns off? cause the psi is at 60 and i dono how to adjust it .. any help would be great thanx
Why are you running 60 pounds of pressure. If you don't have the instructions for the FPR-call B&M or maybe someone here can help you set it. You should be closer to 40 pounds for a stock motor. Also, check that all of the vacuum lines are connected correctly.
as for fuel pressure 60 psi its wayyyyyyyyyyy to high... u need to take it down to like 40 psi..... use a 12mm wrench i beleive, and loose the nut on top of the FPR, right on the middle of the nut , theres a screw....turn the screw , and watch the fuel go down..... when u get to the desired psi, turn the nut so u can lock the bolt.... thats easy....
You loosen the locknut and then turn the shaft that the nut is circling (the nut doesn't do anything for the pressure). If you look closely at that shaft you'll notice it has two flat spots on it for an eensy wrench.
jdm_rb20
Apr 14, 2013 06:51 PM
mattmelton08
Apr 29, 2008 06:52 AM
