obd1 injectors on obd0 setup?
I have obd1 injectors in my ls swap... I know that you can't use obd2 in obd1 or obd0, but I haven't read or heard anywhere that you can't use obd1 injectors with an obd0 ecu. please let me know if I can or can't.
You can use you original injector clips, but you have to CAREFULLY dremel out the corners on the inside of the injectors. Its a little ghetto but it works just as good.
you can use any type of injector so long as you keep a resistor box with obd0 injectors, and delete the box if using obd1/2 injectors. since you are using obd1 injectors you will need to delete the box. start by disconnecting the box and setting it aside. then take the 5 wires that went to the box, and solder them together. wrap up the connection securely and you're done.
Randysi
Apr 4, 2012 10:17 AM
D.Dappa
Jan 18, 2005 06:56 AM
