how do i clean these?
Old Dec 29, 2009 | 01:33 AM
dleccord's Avatar
Default how do i clean these?
im in the process of cleaning out my egr ports on the manifold and i ran into this. can i use simple green to clean them out? also how do i clean the gunk located in the fuel chambers on the head?
thanks
Old Dec 29, 2009 | 09:14 AM
dleccord's Avatar
Default Re: how do i clean these?
anyone ?
Old Dec 29, 2009 | 09:18 AM
nus_dogg's Avatar
Damn, thats dirty. I don't know if carb or brake cleaner will hurt it but I'd use some clean towel and get as much as possible off first.
Old Dec 29, 2009 | 09:47 AM
dleccord's Avatar
i wonder if it will hurt if the gunk falls back into the fuel chamber on the head.
Old Dec 30, 2009 | 07:58 PM
notAdiesel's Avatar
i'm pretty sure there's a sticky for this in the how-to section
Old Dec 30, 2009 | 08:03 PM
notAdiesel's Avatar
EGR Port Cleaning for 90-97 Accords
94-97 Accord EGR Port Cleaning
Fix for CEL Code P0401 (EGR Port Cleaning)
EGR Port Cleaning for 98-02 Accord V6
EGR Block Off (F22B1 & F22B2)
Old Dec 30, 2009 | 08:04 PM
notAdiesel's Avatar
http://home.comcast.net/~em-engineering/T2T013.pdf
http://www.freewebs.com/hondadude/95...5AccordEGR.htm
https://honda-tech.com/forums/honda-accord-1990-2002-2/diy-fix-all-had-p0401-code-2674082/
http://www.tegger.com/hondafaq/tsb/accord/A99-085.pdf
https://honda-tech.com/zerothread?id=442008
in that order
Old Dec 30, 2009 | 09:08 PM
slomofo's Avatar
GDD Member
Use carb cleaner, but that gunk doesn't affect anything. Your fuel spray comes out of the tip and yours appear to be squeaky clean.
Old Dec 30, 2009 | 11:25 PM
dd97accord's Avatar
New User
he isnt talking about the EGR...the gunk looks worse than mine when i did this..do what you can to remove most of it then spray throttle body carb cleaner in there for the rest to get removed..the injectors clean with the carb cleaner too..
it helped my mpg for a little while..but now its going back down again, im going to check it one of these days
Old Jan 1, 2010 | 05:05 PM
notAdiesel's Avatar
mine just dropped too a couple weeks ago, i was wondering if it was because i've been using the heat more since it's been colder
Old Jan 1, 2010 | 05:24 PM
dleccord's Avatar
just a follow up...i installed my fuel injectors in as well as the rail and after that there was fuel spraying where the injector's butt goes into the rail on the 4th cylinder. the remedy to this was the o-ring, which COSTS $6 F!@#&*^% for the tiny *** ring!
anyways, use motor/atf oil to lube those little rings on the injector. when i took mine o-ring out, it was ripped so that's why the fuel leaked out.
justinope
Oct 5, 2013 12:27 AM
nhldogg
Apr 17, 2010 11:32 AM
2piecescar
Feb 25, 2008 06:12 AM
Serdar
Aug 24, 2005 10:56 PM
