WTB D16Y8 m/t stuff
BUMP IF VEIWED!!!
BUMP IF VEIWED!!!
BUMP IF VEIWED!!!
i am doing an auto to manual swap in my 96 coupe, as of right now,i have some things..lmk what you have!
i need:
intake mani.
all the needed sensors
wire harness
pedal assembly
m/c
mounts
linkages
shifter
BUMP IF VEIWED!!!
BUMP IF VEIWED!!!
i need:
intake mani.
wire harness
pedal assembly
m/c
mounts
linkages
shifter
ive got pedal assembly clutch line master cylinder trans out of a db7 thatll work and also have single cam linkage with shifter and y8 manifold and also fivespeed harness.... basically everything you need to do the 5spd swap because i was gonna do it in my 4dr but decided to DD it as an auto and get something five speed later.. call me if you have any questions 205 249 3369
cool, how much would you charge if i came to pick up, i have the trans, bu when i can get a little more money ill hit you up!
