ls rods in d16
Old Dec 28, 2009 | 05:33 PM
adam00's Avatar
Default ls rods in d16
Would anyone be able to machine ls rods to fit in a d16y8 with vitaras? I know its possible and has been done before but I dont know anyone local that I trust doing it.
Old Dec 28, 2009 | 06:06 PM
d16sandrail's Avatar
Default Re: ls rods in d16
I can, PM me for detail$
Old Dec 28, 2009 | 06:13 PM
kandstd16t's Avatar
i want to do the same thing if you find out details can you tell me what you did
Old Dec 28, 2009 | 06:43 PM
turbo sol's Avatar
not to rain on d16sandrail parade, maybe he can cut you a hell of a deal… my experience is it cost me over 200 to do this about 5 years ago. eagle rods aren't much much and offer a better piece of mind. IMO.
one up side though would be that you don't need to notch the block with LS rods.
Old Dec 28, 2009 | 06:52 PM
91jdmhatchback's Avatar
I have a local machine shop that did mine for $150 and that included the bushings from crower. LMK
Finish modded ls rod
Ls rod next to d15 rod
Old Dec 28, 2009 | 07:40 PM
adam00's Avatar
I'm not looking to spend that much on the rods, im just trying to make a cheap little build. Also i already have eagle rods and vitara pistons i bought off a local guy for $175 but im want to save those rods for my next build.
Old Dec 28, 2009 | 07:46 PM
Well then good luck with your build. the amount of time it takes to do the machining properly is what adds up the cost. You can't beat the price when you think about the benifits to them.
- 400whp rods
- oem quality
- cost effective
If $150 is to much, not much i can tell ya.
Old Dec 28, 2009 | 07:55 PM
adam00's Avatar
- 400whp rods
- oem quality
- cost effective
What kind of build did you do with ls rods?
Old Dec 29, 2009 | 05:41 AM
turbo sol's Avatar
if you can get it for 150. thats a good deal.
if you are shooting for over 300hp I would pony up for eagles, or FJT has made some custom rods to correctly place vitara pitsons.
here are the 2 set ups I have built.
LS rods with SRP pistons / stock z6 rods and pistons
stock z6 rods / Eagle rods with Vitara pistons
Old Dec 29, 2009 | 06:25 AM
boost ben's Avatar
Slightly off topic but how much to LS rods weigh?
Old Dec 29, 2009 | 06:28 AM
turbo sol's Avatar
i can't remember, but they weren't the lightest things. maybe one of the guys who still have them apart could weigh them?
Old Dec 29, 2009 | 06:30 AM
rota92
Guest
Posts: n/a
Why would anyone not spend another 150 to get Eagle rods for 300 shipped from pretty much EVERY dealer in the country? lol
Old Dec 29, 2009 | 07:03 AM
It all comes down to cost vs. nesecity. I do not need eagle's so i went with these rods. Like everythign, you don't need a ball bearing turbo to make 400 whp a journal bearing works fine. But it sure is nice to have a better stuff.
Old Dec 29, 2009 | 07:07 AM
adam00's Avatar
I guess im just gonna use the eagle rods that i already have and hope that my ebay 57 trim doesnt ruin my motor. Then for my next build ill buy the fjr spec rods.
Old Dec 29, 2009 | 06:19 PM
m R g S r's Avatar
yeah but the price difference there is a lot more than in this case. the $150 for a bulletproof setup seems like it's worth it IMO.
Old Dec 29, 2009 | 06:29 PM
builthatch's Avatar
MiG-21 superfan
y0, are vitara pistons press-fit...and, what size is the pin on them?
reason i ask is...
in 1999 i built my first D. it was 12.5:1 with spray. i ended up using peened LS rods, but with custom forged pistons. the dummy who i consulted suggested getting the pistons made to accomodate the larger LS .826 (IIRC) small bore.
mistake.
anyway, i wanted to reuse the rods in a later NA build with press-fit pistons and my research showed me several examples of, when the small bore was re-bushed to accomodate the .747 pin of the smaller pistons, the bushing actually rotated in the bore (eventually).
so, i ended up just using peened y8 rods and trashing the idea of re-bushing the LS rods i used previously, but that was ok since i was only NA.
Old Dec 29, 2009 | 07:58 PM
adam00's Avatar
[QUOTE=builthatch;41082441]y0, are vitara pistons press-fit...and, what size is the pin on them?
The vitara's are full floating pistons and the wrist pin size is 19mm.
Old Dec 29, 2009 | 08:41 PM
builthatch's Avatar
MiG-21 superfan
ahh, ok, so normal d-series size @ .747-8
full-floating, that's good. bushed small bore will work just fine for that vs. press-fit.
thanks.
Old Dec 30, 2009 | 06:08 PM
h2.4's Avatar
Fu*#in' Honda-Tech, I agree with rota, who the ____ would spend money to mod stock rods for a boosted setup. Get some eagles for fu-ks sake. What are you guys doin'? HMT 4life. lol.
Old Dec 30, 2009 | 11:31 PM
engine_runner's Avatar
what exactly is being machined on the ls rods to fit the vitara pistons? is it the wrist pin inner diameter to allow floating wrist pins and or the thickness of the rods piston end to fit into the vitara piston? also i heard of people using b16 rods any difference between the two?
Old Dec 31, 2009 | 07:15 AM
turbo sol's Avatar
the question in this post was about fitting LS rods to vitara's in a d16. to do that you have to:
1. create a bushing for the wristpin (LS wrist pin is bigger than d16/vitara wrist pins)
2. thin down the LS rod around the main bearings, so it fits on the d16 crank (between the counterweights) - you can see this area already machined on the images above.
LS rods are used bc they have the same length as d16 rods. b16 rods would be too short .
I too have heard of people using b16 rods, but that is in conjunction with Supra pistons (over seas model only).
https://honda-tech.com/forums/forced-induction-16/anyone-still-interested-toyota-b16a-hybrid-piston-rod-package-sohc-d-series-engines-267641/
if you're into NA you can find a civic GX (natural gas) d16 and mate it to an LS rod without the bushing, (if memory serves correct) for an High compression sohc.
but like everyone said above, spend an extra 150 and get eagles. I did it both ways, and wouldn't do LS rods again. Eagles were less hassle and give me piece of mind.
Last edited by turbo sol; Dec 31, 2009 at 07:18 AM. Reason: part about supra pistons
Old Dec 31, 2009 | 08:30 AM
https://honda-tech.com/forums/showthread.php?t=267641
so for the eagle rods they are just regular d series rods but beefed up of course and no special lengths to keep in mind and they are already floating wrist pin setup perfect for vitara corret. no other mods necessary to install.
Old Dec 31, 2009 | 11:25 AM
rota92
Guest
Posts: n/a
That's the worst analogy possible, a ball bearing turbo isn't more reliable as would an Eagle rod to an OEM cast rod.
This is about reliability and doing things right, instead of a Tial BOV use a DSM to save that 150 bucks or something lol I don't agree all that much with a Vitara piston either but I let that slide usually, but the rods can be used for ages without breaking whereas a stock rod is just that, stock.
Old Dec 31, 2009 | 12:48 PM
welfarepc's Avatar
its hard to argue with the whole vitara piston thing rota. i know forged is better, but damn that james @ speedfactory just keeps doing things with the vits... lol
Old Dec 31, 2009 | 01:25 PM
AMGkobez's Avatar
http://www.fjdistributors.com/ has vitara pistons and rods for this setup
d-series.org has covered this a bunch of times and many suggest against using ls rods in a d.
94-integra-ls
Dec 2, 2010 10:48 PM
civic-r11
19
Jul 14, 2009 06:53 AM
S9i1R
Mar 23, 2004 09:01 PM
dust
May 22, 2003 12:24 PM
