ef sedan headlight problem
this is something i've noticed more and more since i've had the car. My driverside headlight assembly "wobbles" for lack of a better word. when im driving i notice the light dissapation shake and vibrate. if i push on the highbeam side of the headlight, the assembly will move about 1/4" inward and then pop back into place when i let go of it.
Also, trying to adjust these things is a nightmare. im "able" to, but the driverside always sits a little higher than the passenger...i dunno it just annoys me.
could i have a loose bolt in the headlight assembly bracket? anyone else experience this?
i use to have this problem in my old ed sedan...simple solution is to bend a piece of cardboard and place it under the headlight between the bracket inside the engine bay and you should be good to go...!!!
it sucks cuz my driversid headlight points higher than the passenger. they are adjusted to the lowest possible point.
i never figured it out myself but the solution i mentioned worked great for 7 years...just rip out a piece of a 12 pack cardboard,bend it tightly and place it under the headlight...!!!
GSblueRacing
Mar 27, 2004 02:27 PM
