shifter to shift linkage problem
Old Dec 28, 2009 | 02:20 PM
skaternak's Avatar
Default shifter to shift linkage problem
does a 97 civic stock shifter fit into a 2000 civic ex shift linkage? cause mine doesnt want to go in between the fork
Old Dec 28, 2009 | 03:55 PM
92lxsleeper's Avatar
Default Re: shifter to shift linkage problem
umm prolly not cause, isn't the 2000 a b series?
Old Dec 28, 2009 | 04:09 PM
civicjunkie17's Avatar
yes it should as long as it's d series and the same generation.
the 2000 ex is a d16y8
a 2000 si is the b series b16a3
Old Dec 28, 2009 | 04:24 PM
BryanM.'s Avatar
Resident Gearhead
The shift lever for ALL 96-00 D series engines are all the same part number.
I bet you've got an EM1 shift lever.
Old Dec 28, 2009 | 05:29 PM
skaternak's Avatar
it fits now. i had to bend the fork back cause i had a ebay short shifter and i had to tighten it tight because it was loose and i think it bent it in
Old Dec 28, 2009 | 05:47 PM
Vindicator9000's Avatar
318 Curves, 11 miles
that'll do it.
To add to this thread a bit, you can use the same D series shifter on any 92-00 Civic from what I've seen. I've been using the same B&M on both my d series forks and my B series forks, and I bought it originally for my y8.
As someone said, the EM1 shifter is slightly wider and doesn't quite work easily on the D series linkage, although a D series shifter will work on an EM1 linkage with no problems at all.
Old Dec 28, 2009 | 07:10 PM
skaternak's Avatar
just wanted to know...do short shifters damage the transmission? or does it make no difference?
Old Dec 28, 2009 | 07:21 PM
not if you shift right.
What damages transmissions is forcing gears too quickly for the synchros to mesh.
Old Dec 28, 2009 | 07:24 PM
skaternak's Avatar
ooooOoo. Thanks for the info. Never knew that.
b20hatchek
Mar 7, 2013 08:48 PM
4tika4
Oct 31, 2009 12:26 PM
Lyle_57IAL
Transmission & Drivetrain
Mar 5, 2009 09:08 PM
1kleenef
Oct 5, 2007 04:58 PM
Dang EG
Apr 19, 2005 10:19 PM
