need help with obd2 gsr in a eg
ok i got a eg coupe with a obd2 gsr runs perfect in all and i want to buy a 94-99 integra ls or gsr shell. what do i need to do the swap i mean do i have to cut or splice the motor harness? my car has obd2 dizzy , injectors. or is it a plug and play harness for the teggy.
If you get a '96-'99 Integra, then it will be plug and play.
If you get a '94-'95 Integra, there are some options on what to do. You can get OBD1 parts (engine harness, injectors, alternator, & distributor) and use them on your engine. You can use the harness (if the shell even comes with one) and cut and splice the connectors for the injectors, distributor & alternator. You can use the engine harness you're currently using for your Civic. Or you can get an OBD2 Integra engine harness.
killaberna
27
Aug 26, 2014 06:44 PM
g356gear
Aug 11, 2008 09:41 PM
