Compatibility Hondata S300
well i have a CRX 88, actually is working with harness and Ecu OBD0 (PM8), but the car has swap d16z6, the Ecu is failing for that reason I have thought about buying one Ecu hondata that it works for this harness and this motor, that hondata Ecu I need for this problem??
thanks
thanks
basically, if you have any 88-91 or 96-00 model Honda, you do and obdI conversion. Then you can run the Hondata S300, which can be setup any D, B, F, and H series engines!
