How low can I drop the subframe/engine on F22b2
Old Dec 28, 2009 | 12:17 PM
zsnarl's Avatar
Default How low can I drop the subframe/engine on F22b2
Trying to drop the subframe/engine.
Would it be possible to drop it about 7" with sway bar/radius rod/transmission attached?
I'm going a timing belt change, but also need to gain access to water pump bolts from wheel well.
Thanks.
Old Dec 28, 2009 | 02:23 PM
nus_dogg's Avatar
Default Re: How low can I drop the subframe/engine on F22b2
I don't think its necessary to do so, because you can gain acess to those water pump bolts & t-belt with the timing covers off. Its just time consuming.
Old Dec 29, 2009 | 08:25 AM
zsnarl's Avatar
The main reason I need to drop the engine is to gain access to a broken water pump bolt - to extract it. The bolt in question is the top right near the cam pulley.
It does seem to be too time consuming, and I may try putting some hondabond at that top right corner of the water pump, bolt down the other 4 bolts and hope it doesn't leak.
Old Dec 29, 2009 | 09:08 AM
nus_dogg's Avatar
Ahhh... I see. If thats the case, yes, you'll need to remove the motor. Why not just yank the motor from up top? Unless you don't have a cherry picker.
Old Dec 29, 2009 | 10:26 AM
zsnarl's Avatar
Yup. no cherry picker. Either options should be just as much work.
Old Dec 29, 2009 | 11:09 AM
cstone's Avatar
a cherry picker wouldn't be too bad to rent if you would rather pull it out the top. seems like the easier option to me but i may be wrong. money could be tight though (i know how that is.) just another option
zsnarl
Jul 26, 2015 11:42 AM
Shaguar47
May 26, 2007 09:40 AM
cifer6425
Jan 7, 2006 10:10 AM
abolish415
May 20, 2004 10:36 AM
.RJ
Jun 18, 2003 10:57 PM
