How bad dose nos mess up your engine?
Old Sep 3, 2002 | 02:43 PM
cr-x si's Avatar
Default How bad dose nos mess up your engine?
I have benn thinking of getting a zex kid for my rex but i don't want to be replacing pistons left and righ. So my question is, How meny shots of nitrous could my zc take? i would probly only use a 50 shot or less.
Old Sep 3, 2002 | 02:47 PM
Steve Berman's Avatar
Default Re: How bad dose nos mess up your engine? (cr-x si)
If your getting a ZEX™ kit you dont really have to worry about NOS™ messing up your engine.
[Modified by Steve Berman, 6:47 PM 9/3/2002]
Old Sep 3, 2002 | 02:51 PM
zcivic91's Avatar
Default Re: How bad dose nos mess up your engine? (Steve Berman)
yea..u cant have a zex and a nos kit at the same time...well u could but that would be very bad!
Old Sep 3, 2002 | 03:46 PM
93eg-EKhybrid's Avatar
SMARTASS!!!!!
j/k I love your way of thinking man!!
double thumbs up for all of the smartasses here!!
Old Sep 3, 2002 | 03:53 PM
EF8_SiR's Avatar
Zex in lack of better words is considered ***** nitrous. Putting in 55 shot or 75 shot wont' do too much harm to ur engine as long as u don't arm and activate it where ever u go. The problem I find is more of stability and security factor. There have been cases where cars been rear ended and the bottle explodes.
If u gonna take this risk might as well really go crazy. Do up ur pistons, rings, copper head gaskets etc and drop in like a 200+ shot of NOS (not Zex) wet injection system
Old Sep 3, 2002 | 03:59 PM
bullz's Avatar
Default Re: How bad dose nos mess up your engine? (EF8_SiR)
You don't have rust on the hole of your car?
Old Sep 3, 2002 | 04:04 PM
Default Re: How bad dose nos mess up your engine? (iLLestjr)
That is your second post in 2 minutes that don't make sense!!
Old Sep 3, 2002 | 04:14 PM
keebler65's Avatar
Default Re: How bad dose nos mess up your engine? (89B16HB)
lol yeah whats up with you?
Old Sep 3, 2002 | 04:16 PM
Malgerus's Avatar
That's what I'm talking about
[Modified by 89_Y_49, 1:16 AM 9/4/2002]
Old Sep 3, 2002 | 04:26 PM
SikofFalln's Avatar
Default Re: How bad dose nos mess up your engine? (89_Y_49)
How bad it mess up your engine all depends, assuming you already have the basic bolt ons I/H/E you should be fine. A buddy of mine put a zex kit on his 92 Si and fried his rings the first night, he also had a stock exhaust. We ran an open header with the kit and it was alot faster. About 1 month after the kit was on he blew up his motor, 4 holes in the block and only one good rod. You could see through the block it was kind of cool. He also works at a shop so they through a D16 in the next day. Just make sure your motor can breath and a 55 shot should do no harm.
Old Sep 3, 2002 | 04:39 PM
Tru Dynamix's Avatar
Default Re: How bad dose nos mess up your engine? (BseriesPWR)
for nitrous systems, i feel its most important that u get a good installer on it...a small shot like 55 shot should be fine but dont squeeze every chance u get...it will not mess up your engine right away but i PERSONALLY feel that through out the years of squeezing, it will shorten the life of your engine...
nitrous is very tricky..if u ask 10 different nitrous "experts" the same questions, u will probably get 10 different answers...
however, if i had to do a nitrous set up, id definitely choose a direct port set up..even though its more expensive for the kit and labor for install, its well worth it considering its safer than wet and dry and u can probably SAFELY squeeze a larger shot.
Old Sep 3, 2002 | 04:40 PM
cr-x si's Avatar
nope no rust the car has been striped to the frame and power coaded
and has new body pannels and paint
Old Sep 3, 2002 | 04:46 PM
cr-x si's Avatar
thanks for the info. i know how to insatll the zex kit it isn't hard i will probly run 55-75 shot but i won't flip the switch very much though. and by the way i just say nos short for nitrous. I know NOS make a wet nitrous system too.
integ_lude
Mar 25, 2008 06:26 AM
95hybridcivic
May 5, 2002 08:36 PM
Nighthawk GS-R
Apr 10, 2002 03:38 PM
ridnmyhonda
Jan 9, 2002 06:38 AM
redteg1
Dec 10, 2001 01:16 PM
