Yager D's Del Sol Build
Old Dec 27, 2009 | 09:04 PM
ImportHatch's Avatar
Default Yager D's Del Sol Build
I have never made a build thread before so please bear with me. I was browsing craigslist the other day like I always do and I found a Del Sol with a blown headgasket for $800. After a bunch of bs trying to get ahold of the guy I finally ended up picking it up for $650. 1993, S model, 185k. Here is pics of it the first day I had it home.
Turns out the thermostat gasket was not seated, not a blown headgasket. 5 mins later I had the car up and running. I was having a problem with no low end power (under 3.5k). I replaced the plugs, cap, rotor and fuel filter with no prevail. (already had new wires on it) Turns out the ignitor was bad, swapped that out and runs like a champ.
Then I ganked the parts off of my eg for the delsol. Here is what the hatch looked like before..... sportmax 15x8 +0, 195/50/15
i
and after..... Donk! ha. Will be lowered back down on the dr9's shortly.
D2 full coilovers, skunk 2 camber arms, Custom rear camber kit, Omni Power LCA's, ASR Polished brace, Drag DR9's..... (suspension techniques sway bar going on soon)
Then my tires finally came in and I mounted up my sportmax 501's, 15x8 +15, 195/45/15
I've worked on the car 3 days and this is where I'm at. I will be installing a lip ASAP. I still need to install my suspension technique rear sway, momo hub, nrg quick release and sparco wheel. The night pics is after I buffed it out today. Turned out pretty good. Anyway, let me know what you guys think and im open to any suggestions you may have. Thanks for looking!
Old Dec 27, 2009 | 09:48 PM
Aaron0526's Avatar
Default Re: Yager D's Del Sol Build
likin in so far, not likin how the pics are so small though, pita to open them all up but still good work
Eteggy
Sep 8, 2015 04:05 PM
donmeca2020
Group Threads
Mar 12, 2012 05:07 PM
Fabian@delsol
Appearance Build Threads
38
Sep 10, 2011 09:18 AM
