mini me head bolts
i plan on running a Z6 head on a B2 block. i have searched to figured out which head bolts to use but i cant find too much info on the set up. i do know and plan on moving up to studs in the future. can anyone lend a hand on my search?
thanks in advance!
thanks in advance!
Basically,
You need to measure the thread length on the B2 head bolts and then measure the thickness of the Z6 head. At that point find a corresponding grade 12.9 bolt that will fit and use that. A bolt like that will only run you about $2.50 each. A 12.9 grade bolt will be much stronger than OEM head bolts and will not stretch.
Twisted Image
Mar 23, 2006 08:59 AM
EK_vzla
Sep 21, 2004 02:15 PM
