Anyone using the AEM fuel rail??? got a problem....
Old Sep 3, 2002 | 02:17 PM
RTW DC2R's Avatar
Default Anyone using the AEM fuel rail??? got a problem....
OK so I have the fuel rail installed, along with the AEM FPR mounted on the right side of the rail. Now, there is another screw(an allen screw) that is not used(I dont think anyway) and fuel is seeping out around that screw. I have tried to tighten that screw down so much thats its not even flush with the rail and its recessed into the rail, but still leaks. Is there some kinda seal or lube **** I should be using for that screw? Did I miss something here? Or is it maybe a defect?? any help is appreciated.
Old Sep 3, 2002 | 02:20 PM
B2FiNiTY's Avatar
Default Re: Anyone using the AEM fuel rail??? got a problem.... (RTW DC2)
Check your stock one. Maybe your missing a rubber seal.
Dirty GS-R's Avatar
New User
Try using some teflon (sp?) tape on the threads.....I was having the same problem with mine and that fixed it.
Old Sep 3, 2002 | 03:13 PM
nfn15037's Avatar
Default Re: Anyone using the AEM fuel rail??? got a problem.... (Dirty GS-R)
Teflon tape r0x
Old Sep 3, 2002 | 03:45 PM
JoshRambo's Avatar
use liquid teflon. works better than tape and it won't rip apart. or if you want mount a fuel pressure gauge there. thats sort of what the hole is for.
Old Sep 3, 2002 | 04:05 PM
RTW DC2R's Avatar
Default Re: Anyone using the AEM fuel rail??? got a problem.... (Gravity)
Thanks
Old Sep 3, 2002 | 04:39 PM
[HrZn]4life's Avatar
Make sure everything is tightened with the correct torque specs with torque wrench. My buddy had a leak and it was because it was overtightened....we checked torque specs and it stopped leaking afterwords...same situation...aem fuel rail.
tooquik209
Sep 11, 2012 12:40 AM
acmoc
10
Dec 15, 2008 05:06 PM
IIVIIoOkY
Mar 21, 2006 03:57 PM
WH0R3nEF9
Apr 1, 2005 09:52 AM
Nate B
Dec 13, 2002 09:20 PM
