Need help with water leak. Driver side rear floorboard gets soaked
After a recent storm I noticed my rear floorboard got soaked. The majority was behind my seat but the carpet under the seat and just about 6" in front (of the seat) got wet too.
I don't know if i found the main cause of the problem but what i found was that when my sunroof it cracked and water was ran over it, the drain tubes were fine, BUT the drain channel itself was spilling over huge amounts of water onto the headliner. I searched but I couldn't find anything about this specific issue.
I haven't seen anything on here that leads to a solution of this common problem with Integras. Theres threads among threads on here about this.
It seems like having my moonroof cracked even slightly and at an incline is resulting from most of the water spilling over. Now, i don't know if this is what's causing my issue because I could swear that I'm leaving my moonroof 100% closed, but I thought I'd address this first because running water over my car for 15 min straight has not resulted in a single drop that I can see. I would check the front drain tubes but for the life of me I can't recall a single time that the water reached the very front.
fattymatty
Jan 2, 2005 07:44 PM
