need base map for s300
Old Dec 27, 2009 | 01:43 PM
b20turbocivic's Avatar
Default need base map for s300
i have an s300 and 1000 cc injectors i need a base map to get the car started so i can drive it to get tuned my set up is b16 bored to a 2.1 , 9.1:1 comp, with a full race ram horn manifold , sc -61 turbo and hondata 4 bar map sensor if someone can send me a base map it would be great thanks
Old Dec 27, 2009 | 01:49 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: need base map for s300
got to hondata's website
Old Dec 27, 2009 | 01:58 PM
i checked the website out already couldnt get anything
Old Dec 27, 2009 | 02:08 PM
OMG B16's Avatar
Ask your tuner to give you one or tow the car.
p.s. Your B16 is most likely not bored to a 2.1L.
Old Dec 27, 2009 | 02:30 PM
HAVideos's Avatar
is this just to get you to a dyno? or to your tuner?
Old Dec 27, 2009 | 03:58 PM
boostedcivicsir's Avatar
Mr. Badwrench
i am actually going to leave it here, because it is against the rules in the engine management subforum to ask for a base map.
although not really tech related, there isnt anything here that says we cant have a thread like this.
hondata does have a subforum where you can put a post about a base map needed.
Old Dec 27, 2009 | 04:52 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
whats your email I will set up a map that should at least start it. I have a map that maybe close. I am not taking any responsibility for anything you mess up. It will be either later tues or wed when i can get it done cause im at work right now.
Old Dec 27, 2009 | 05:29 PM
boostek9's Avatar
i have a gsr, 1000cc, 4bar map, 62-1, if i can figure out how to send it
Old Dec 27, 2009 | 08:17 PM
cjordan's Avatar
just attach it to an email, you attach it like you would a picture except you go to the smanager file ( which is most likely on your desktop ) and select whichever map your trying to attach. i have emailed my maps to a buddy to check a couple times.
Old Dec 27, 2009 | 09:40 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
yours would be better suited for his setup, I would have to go in and change somethings around
Old Dec 27, 2009 | 09:50 PM
The guy i want to get it dyno at is about 1 hr. from where i live i just need to get the car started to get there. When i put the stock injectors on and wire everything back up to stock the car runs fine , i just want to get the car running with the 1000cc and how its wired up now with the resistor box.
Old Dec 28, 2009 | 12:33 AM
HAVideos's Avatar
understandable. its a shame you have to travel so far for a tune. good luck with the car man.
Old Dec 28, 2009 | 11:28 AM
SpiderSol's Avatar
for sure its not 2.1L
its very easy to create your basemap from hondata supplied tunes, if dont to know how its done then dont run your car and wait for a tuner...
Old Dec 28, 2009 | 11:31 AM
SOHC_MShue's Avatar
If you have s300 then there is no reason your tuner cant easily send you a basemap through email for the ecu.
CiViC SiR's Avatar
2.1L from b16??
run with your stock injectors and install ur 1000cc injector when u arrive
sewokozak
Engine Management and Tuning
Aug 9, 2018 02:08 PM
Mjalaly
Jul 7, 2015 09:25 AM
i.
Feb 12, 2009 11:50 AM
Patron
Mar 21, 2004 03:42 PM
