Honed b16 block - Scratches still there - See PIC's
Old Dec 26, 2009 | 10:19 PM
teamasr1's Avatar
Icon6 Honed b16 block - Scratches still there - See PIC's
I just honed my block with a 400 grit hone ball. When I drop a light into the block I can see a nice cross hatch pattern but I also see fine vertical scratches in several parts of each cylinder. They do NOT go all the way top to bottom, each one is only a couple of CM long. When I run my nail in the cylinder to feel them, unless I knew to look for them, my nail would not catch them.
Am I going to be ok?
I took it apart because it was smoking, so hate to put it back together and not achieve what I was after?
Old Dec 26, 2009 | 10:56 PM
welfarepc's Avatar
Default Re: Honed b16 block - Scratches still there???
if you want to be sure, get it overbored to 75.5 and be done with it
or be frugal like myself and reassemble with new rings and the hone and see what happens.
Old Dec 26, 2009 | 11:02 PM
rhd_sir2's Avatar
^ you mean 81.25mm or 81.50mm, its a b16
To the OP, your best bet/safest bet is to send it out and get it over bored slightly to 81.25mm to get rid of those scratches. If you dont you may continue to burn oil as it will 'hide' in those scratches
Old Dec 27, 2009 | 09:21 AM
teamasr1's Avatar
ic so even if the scratches don't go all the way top to bottom, it can still burn oil from oil hiding in the scratches?
How deep of a scratch will cause that? I mean I can barely get a nail in these lines.
If I take it to a machine shop, i assume i need to take the crank out? if that is the case, i might be better off just buying a b16 block from someone how just needed the head off of.
Old Dec 27, 2009 | 02:36 PM
teamasr1's Avatar
Here are a couple of photos. Don't mind the bubbles, that is fresh oil on the walls.
Old Dec 27, 2009 | 10:26 PM
king06's Avatar
Default Re: Honed b16 block - Scratches still there - See PIC's
Get it bored.
Old Dec 28, 2009 | 01:56 AM
CoreyR's Avatar
i would run it like that. does your fingernail catch on it if you run it across?
Old Dec 28, 2009 | 04:01 AM
Vagitarian's Avatar
Absolutely wont have a problem with running like that
Old Dec 28, 2009 | 05:00 AM
non-VTEC's Avatar
run it.....mine had huge scratches which are visible and you could feel them. i just shoved the damn pistons in anyway. the engine rungs great. great compression and leak down.
Old Dec 28, 2009 | 09:39 AM
miguel329's Avatar
^ u got lucky lol i did that and few months later burning oil... id say bore it..
Old Dec 28, 2009 | 01:27 PM
teamasr1's Avatar
nail tip barely catches on it. If I did not know the lines where there and I ran my nail, I don't think I would know that my nail caught on it.
I think I'm just going to run it. see what happens.
Old Dec 28, 2009 | 05:34 PM
turbociv910's Avatar
that wall is ruined.
god i love it when people know what they are doing.
Old Dec 28, 2009 | 08:12 PM
teamasr1's Avatar
What do you mean 910? Because of the vertical scratch or my excellent hone job?
Old Dec 29, 2009 | 09:50 AM
Scott_Tucker's Avatar
Did you measure the bore diameter? Usually there is wear associated with scratches like that. No one here can predict accurately whether or not that engine is going to run well or burn oil by simply looking at pictures on the internet. Your hone job looks correct but hopefully you did not take too much material off or your piston to wall clearance will be excessive. My professional opinion would be to bore it oversize but since you are doing the work yourself it's worth a shot just putting it together and seeing what happens if you don't mind the possibility that you will need to do it again in the future.
Old Dec 29, 2009 | 11:06 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^.
I would never just go ahead and use it the way it is, unless you don't mind pulling the engine again.
Get it bored out, do it right the first time. 94
Old Dec 29, 2009 | 08:12 PM
teamasr1's Avatar
Alright, that is what my gut told me to do, bore it out so I decided to go that route. That said, I figured if I am going to dump the money into it, i'd be better off with a b18c, so picked up a block with ctr pistons, but I think i am going to bore this one out and do a fresh build. Anyone want to trade larger size CTR pistons for standard ones?
Old Dec 30, 2009 | 11:32 AM
seanbev24's Avatar
That's gonna be some crazy compression, why not get some 81.25 or 81.5 p30 pistons and sell the ctr's
cubish
Nov 18, 2006 12:22 PM
G2hybrid
Dec 9, 2004 10:26 AM
CATCH DIS HATCH
Jun 15, 2004 10:35 PM
20lbbooster
Mar 4, 2004 02:09 PM
