01 GSR CEL
Hey so I was driving around yesterday and the integra was running fine, no problems whatsoever, and parked to go into a store. When I came out and turned on my car a CEL came on. I went over to autozone to get the code pulled and found that its either an electrical issue or a bad CKP sensor.
Also another weird thing is that when the CEL came on my oil pressure guage dropped and is now running constantly between 20-40psi (40 under load), no oil leaks or anything though. The oil problem actually happened before it just dropped out of nowhere and I did an oil change and it went back up...i just don't see why its fluctuating like that...maybe its a bad gauge?
Anyways can anyone give me any suggestions on how to fix this? I called up import powerhouse(local shop) and they said that the CKP sensor may need to be cleaned, i just wanna know if anyone else has had any similar problem to this or can give me any suggestions.
Thanks in advanced
Thanks in advanced
DumpedSi
Aug 14, 2003 02:41 PM
