WTF is up with my temperature?!
Old Dec 26, 2009 | 07:29 PM
markspan6243's Avatar
Flattery Will Get You Everywhere
Default WTF is up with my temperature?!
i have a 1994 del sol si with the stock d16z6. so i get in my car today, and i let it warm up. the needle gets to where its supposed to, so i start to leave. not 50 feet down the road i look down at it, and it is already half way down to C. another 50 feet, and its all the way down to cold. it does this every winter! what is wrong with my car? is it the thermostat? the fan switch? help please!
Old Dec 26, 2009 | 08:08 PM
tico's Avatar
Default Re: WTF is up with my temperature?!
dude lets take a step back and think. ur driving in cold weather, as u drive the airflow cools down the coolant through the radiator and also cold air over the engine. mine does the same thing ive checked everything and its all good.. i would be concerend if it never warmed up at all
Old Dec 26, 2009 | 08:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
cold weather will aggrivate a bad t stat. if it is already bad, the cold weather makes it worse.
every honda i have owned, i have to replace the t stat hahaa for the same reason.
Old Dec 26, 2009 | 08:55 PM
under"S"timated's Avatar
when you turn on the heater is the air cold or hot. my car has been trippin it says that it hot when i turn the heater on all i get is cool to warm air. huh go figure.
Old Dec 27, 2009 | 10:04 AM
so do i need a new thermostat? cause my brothers civic heats up, along with all the other cars in my family. the heat gets warm, but never really hot
Old Dec 27, 2009 | 10:11 AM
300whpej's Avatar
if your heat doesnt make you sweat on full blast i would check your thermostat and change it. there like $10 from autozone, or $25 if you must have one from honda. my car does the same thing, but my heat stays hot.
Old Dec 27, 2009 | 10:20 AM
Corksil's Avatar
change the thermostat for starters. then flush and bleed air out of the cooling system when you refill it - you could even tip the ratio a little more towards coolant than water so you don't end up with ice in your radiator.
shady3260
Aug 9, 2012 03:04 PM
accord0494
Honda Civic (2001 - 2005)
Apr 14, 2012 05:40 AM
Masho
Jan 30, 2012 12:09 PM
dankstereg6
Jan 2, 2010 10:02 AM
eurodeseo
Jul 4, 2006 06:55 PM
