doing a rear brake swap on crx, need advice
I have a 91 crx and I bought 95 integra rear trailing arms with all of the asociated control arms. My question is this- I know the rear trailing arms are the same, but I noticed the lower control arm is diferent, but comparing the two arms the bushing distances seem the same but the integra arm is beefier. Is it interchangeable with the crx lower control? Any chance I have to beef up the suspension I'll take. I use this car for rally. thanks.
88-91 civic/crx, 92-95 civic & 94-01 integra rear LCAs are all interchangeable (* the 88 crx and integra type-r use a lighter "box-style" rear LCA, which will work as well, KONI lists the same shock for 88 EF and ITRs; which use an "eye n needle" shock versus the more common "fork" style shock with the heavier "toothpick" LCA). side by side, EF, EG & DC LCAs are the same length, so you won't have any issues with your alignment. the differences between the gens are the holes available (or not available) for mounting a rear sway bar.
