FS: Full Integra GSR Disc Brake Set Up
Old Dec 26, 2009 | 06:57 PM
swainsol's Avatar
Default FS: Full Integra GSR Disc Brake Set Up
Erik
Nashville,TN
$300
h22swain@yahoo.com: 615-971-1369: PM
Will send any pictures you want through email
I have a full disk brake swap set up off of a 94 integra.
Full front spendals, clapers, rotors, pads, ball joints, upper control arms, brake lines/ hoses.
Full rear discs trailing arms, rotors, calipers, pads, hoses/lines, e-brake cables
Also comes with brake booster, master cylinder, and prop valve
Absolutly everything you would need is included even if you need bolts i have those i can give you.
Will split front from rears if your interested in one and not the other
Old Dec 28, 2009 | 04:44 AM
swainsol's Avatar
Default Re: FS: Full Integra GSR Disc Brake Set Up
bump
crazicaveman
Mar 23, 2008 02:36 AM
jugodmyko
11
Mar 12, 2007 12:26 AM
jdmscene
Oct 14, 2006 11:24 AM
