Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Increase compression ratio on TL 3.2
Old Dec 26, 2009 | 06:25 PM
Acura-Power's Avatar
Default Increase compression ratio on TL 3.2
I have an 2003 Acura TL. It is a non S type. I would like to raise the compression in hopes to increase my fuel economy.
I noticed that the s-type has a 10.5 compression ratio compared to the non s-type which is 9.5.
Does the s-type have a higher compression ratio because of a different head gasket, different head or a different cam that allows an increased flow or all of the above? I heard that if I replace the head gasket with a stock or OEM one and take out a few of the layers that it will increase the CR. Will I have to buy a computer that will allow the change to be realized?
Second, Does the non s type TL have high flow cats?
Thanks
Old Dec 26, 2009 | 06:47 PM
slomofo's Avatar
GDD Member
Default Re: Increase compression ratio on TL 3.2
The TLS has higher compression pistons.
Cams don't change your compression ratio. You can go with single layer head gaskets if you want to increase the compression ratio, but it's not going to change much. I think the stock gasket is a 3 layer (not sure on this), so if you went to a two or single layer head gasket, the compression probably wouldn't go any higher than 9.7:1.
Old Dec 27, 2009 | 02:19 AM
imzjustplayin's Avatar
yeah but cams DO allow you to change your dynamic compression...
Old Dec 27, 2009 | 07:02 AM
Thanks for the reply.
I have been running 30% Ethanol and my vehicle seems to love it. Plus it is much cheaper than buying 93 octane fuel.
So if I went with a single layer head gasket I may get a slight increase in CR.
Does the TL type S use the exact same heads as the non S type?
How much piston clearance do I have if I get my head milled or am I better changing the pistons?
Is there a place that someone can recommend where I can get domed pistons and thinner head gaskets. Ethanol loves high compression.
Old Jan 6, 2010 | 07:56 AM
JDMUA5's Avatar
New User
do a 3.5 conversion... use 2002 RL pistons and the honda odyssey crank....
Old Jan 8, 2010 | 09:17 AM
Icon7 Re: Increase compression ratio on TL 3.2
If I change the crank and pistons wont I then have a 3.5? I am really looking for better fuel economy.
Old Jan 10, 2010 | 06:22 AM
rajca's Avatar
get type s heads (cam and valves are diff), type s piston or rl pistons.
Old May 23, 2024 | 05:10 PM
Yoe's Avatar
Yoe
Thanks
it's 10.8.1 if you have the heads milled.
Acura-Power
Engine Management and Tuning
Jan 3, 2010 01:20 PM
High Reved Racing
Jul 14, 2008 04:37 PM
d.n.d.
Jul 17, 2005 08:39 AM
