92 accord steering is whining
Old Dec 26, 2009 | 09:52 AM
Ed ke6bnl's Avatar
Default 92 accord steering is whining
My 92 power steering is whining the fluid level is ok(but foamy) and it will whine and get louder as you drive. Got any suggestions ED
Old Dec 26, 2009 | 10:39 AM
CuteAccord's Avatar
Default Re: 92 accord steering is whining
Try changing the PS belt. If that doesn't fix it and there is no real mechanical problem, just let it be as long as it is not extremely loud. The car is '92, it is bound to have some issues.
Old Dec 26, 2009 | 10:55 AM
19Accord97's Avatar
Alot of Chevys have this problem. It is more than likely on its way out, but it will be awhile before it dies.
I am not exactly familiar with how the PS system works, but in general, foam is NEVER a good sign. Usually in a system there is a pump to pump the fluid around to where it is needed and more often than not, the fluid is what acully keeps the pump cool. If the pump is sucking up foam it won't be able to cool it and will cause the pump to burn up.
A good example is a submersible pump such as one to empty a pool. If you remove it from the water it will get extremely hot within minutes and burn up.
Old Dec 26, 2009 | 11:31 AM
slomofo's Avatar
GDD Member
Foam usually occurs when you put the wrong fluid in a Honda pump. Noise usually occurs when the belt is loose, the pump is going out, or if you have the wrong fluid in there.
smcdonaldaz
Acura TSX
Dec 10, 2019 01:21 PM
Apotack
Jan 29, 2016 10:39 AM
onunezp
Nov 16, 2015 03:05 PM
dhorst88
May 12, 2012 06:56 AM
