LS fuel pump replacement
The fuel pump in my '97 Integra LS may be dying. If it does fail, would it be worthwhile replacing it with a higher flow OEM or aftermarket fuel pump? As far as mods, I don't expect to go beyond I/H/E, and possibly cams. I can probably pick up a used GSR or ITR fuel pump for less money than aftermarket. Will a higher flow fuel pump require other upgrades, such as a fuel pressure regulator?
TIA!
TIA!
TIA!
TIA!
if you ever plan to go beyond I/H/E +maybe cams like upgrading the entire fuel system .. fuel management .. and air/fuel gauge and adding stuff like nitrous or turbo or sc ... go ahead and gett the new brand name .. like a holley 255lph or i think people like to go with the walbro ? i guess its cheap i dunno .. but same flor rate i think 255 lph
