Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
I'm flushing my transmission right now
Old Dec 25, 2009 | 11:47 PM
dleccord's Avatar
Default I'm flushing my transmission right now
okay not actually flushing it but i just changed the atf.
should i drain and fill again after 1000 miles? i want to do 3 drain and fills to get a clean flush but i dont know the intervals in doing so.
thanks.
Old Dec 26, 2009 | 04:53 AM
BLKFLSH's Avatar
Default Re: I'm flushing my transmission right now
You don't have to go 1000 miles. You only need to cirulate the new fluid with the old, which should be done within 5 miles. Make sure the transmission shifts through every gear, including reverse, a few times, and you should be ready for the second drain and fill. What condition was the fluid in, when you drained the first 3 quarts? If the fluid was dark, and the magnet (on the drain plug) was a blob of metal, yes I would do it again.
Old Dec 26, 2009 | 11:48 AM
dleccord's Avatar
well it was brown but still transparent brown. as if it was dirty from the original red color, but im not sure if original honda atf was used but all i remember was that the atf was transparent brown.
northtexas
Honda Civic (2006 - 2015)
10
Sep 25, 2013 09:29 PM
edwinbaby
Jul 25, 2013 07:13 AM
bemused
Jul 25, 2013 06:27 AM
eddieE
Feb 4, 2013 05:12 PM
dan_g
27
Oct 5, 2009 03:06 AM
