95 Eg swap running odd
Old Dec 25, 2009 | 08:25 PM
Jdm John's Avatar
Default 95 Eg swap running odd
Well I recently swapped in a "mini me" (z6 head & b8 block) I ran it a few times without vtec or the o2 sensor wired and it seemed to run fine. But ever since I wired vtec and the o2 sensor it has ran bad. I will start it and the idle will be high. I'll let it run for a few minutes then drive it for maybe like 5 mins. I notice that the response is kind of delayed. Then I will turn it off and it wont start after like it's flooded or something. So then I will let it sit for the night and the next morning it starts but has the same symptoms. I'm just confused on where I should start troubleshooting.
Possible things that could have caused it:
1)When I first attempted to wire vtec i de-pinned the wrong wires because i counted the wrong way on the plug.
2)Something to do with the 02 sensor?
3)Gas has sat in the car for a LONG time.
Symptoms:
1)Black spark plugs
2)Exhaust smells like gas really bad
3)Higher idle than normal
4)weird throttle response
5)Car won't start again unless it sits for a while
I'm trying to get this figured out so I can get my car running good so if anyone can help I'd appreciate it. Thanks
Old Dec 26, 2009 | 01:06 PM
Jdm John's Avatar
Default Re: 95 Eg swap running odd
bump..anyone?
Old Dec 26, 2009 | 01:13 PM
Gunmetal_B20_Hatch's Avatar
CEL codes???
Old Dec 26, 2009 | 01:21 PM
Anon51's Avatar
ecu being used?
Old Dec 26, 2009 | 04:50 PM
Jdm John's Avatar
Originally Posted by Gunmetal_B20_Hatch
CEL codes???
Zero CEL's
Anon51: I'm using a p28
pdetering186
Dec 27, 2012 10:06 AM
EJ1_CRIS_909
Mar 2, 2011 02:01 PM
cashkeith
Dec 9, 2009 05:50 PM
