Obd1 jdm swap question
Old Dec 25, 2009 | 08:05 PM
em1si5853's Avatar
Icon2 Obd1 jdm swap question
When swaping a obd1 jdm b16 into a obd1 car will the engine harness work or do I need to get a usdm harness?
Old Dec 26, 2009 | 08:33 AM
CivicSpoon's Avatar
Default Re: Obd1 jdm swap question
A USDM one, unless you have the time and knowledge to extend a bunch of wires for various sensors. Being that the JDM cars are RHD, the ECU is on the other side of the car; meaning the harness runs to the opposite side as well. So using a USDM (LHD) harness will be much easier.
Old Dec 26, 2009 | 08:38 AM
myronwong's Avatar
well i seen someone work it with a jdm harness. all they did was loose up the harness from the engine and loosen up the dash harness so that both harness will have slack and crossed the engine harness wire to reach each plug on each strut tower.
Old Dec 26, 2009 | 11:03 AM
HondaPartsHero's Avatar
Technical Hero
Just use your harness and add the wires for VTEC and knock sensor
Old Dec 26, 2009 | 11:45 AM
Epichondagod's Avatar
Is this an Obd1 car or was it Converted ?
hannslebo
12
Jun 4, 2009 12:24 PM
Prudz_lude
Dec 14, 2008 11:45 AM
Kirk@SyndromeAuto
Dec 13, 2006 05:24 PM
CLICC916
Aug 13, 2003 05:43 PM
g's integ
May 18, 2002 09:16 PM
