96 accord struggles at start up
Old Dec 25, 2009 | 07:20 PM
dleccord's Avatar
Default 96 accord struggles at start up
im seeing that every time i start up my 96 accord 2.2, it struggles at the start (lke rough idle) for about 2 seconds and then its smooth from there.
is it a weak battery? clogged egr? needs valve adjustment?
thanks
Old Dec 25, 2009 | 07:21 PM
dleccord's Avatar
Default Re: 96 accord struggles at start up
i forgot to add that it cranks fine its just after motor is on, it struggles/shudders for 2-3 seconds and then runs normally/
Old Dec 25, 2009 | 11:20 PM
nus_dogg's Avatar
Try cleaning out your EGR first. But, there might be some other issues; just can't think of anything that would cause it to do that.
Before I cleaned out my EGR ports, my car would sorta sputter while keeping a steady pace on the highway. Its very annoying. So after those ports are opened up and free, car ran smoother than ever and no more sputtering.
Old Dec 25, 2009 | 11:42 PM
dleccord's Avatar
yeah but my car doesnt sputter after 3 seconds of the engine being on. it only has this problem at the beginning of being turned on. after that, it drives perfectly normal.
Old Dec 26, 2009 | 10:43 AM
CuteAccord's Avatar
Valve adjustment. Happened to a Civic of mine. About two months after I saw those signs, it would not even start up at all.
Old Dec 26, 2009 | 08:41 PM
dleccord's Avatar
anyone else?
i never did a valve job on it since i got it at 114k miles. now its 190k
Old Dec 27, 2009 | 12:09 AM
Dannyvho's Avatar
Has the throttle body and IACV been cleaned? This IACV valve feeds in extra air to adjust the idle rpm.
At 190k miles me too I would consider adjusting the valves (see FAQ).
Old Dec 27, 2009 | 12:25 AM
slomofo's Avatar
GDD Member
You could always start with the basics and try changing your fuel filter. It could be low fuel pressure in the lines from being parked all night which might be signs of a fuel pressure regulator problem. It could be IACV related, it could be a number of things, but it's always nice to start out with the basics.
Old Dec 27, 2009 | 09:57 AM
dleccord's Avatar
ugh isnt the fuel filter a PITA to change on our accords?
Old Dec 27, 2009 | 09:59 AM
slomofo's Avatar
GDD Member
Not really, it's under the master cylinder/intake manifold, but it's really not that hard to change.
Old Dec 27, 2009 | 10:10 AM
dleccord's Avatar
for the 96 accords? i thought it was on top of the fuel tank? i read you need a crowsfoot to remove it?
Old Dec 27, 2009 | 10:38 AM
slomofo's Avatar
GDD Member
Why don't you just walk over to your car, open the hood, and look under your master cylinder to confirm?
Old Dec 27, 2009 | 10:40 AM
dleccord's Avatar
the master cylinder is the black cylinder that connects to the brake fluid reservoir?
Old Dec 27, 2009 | 10:52 AM
slomofo's Avatar
GDD Member
That's the brake booster, but yeah, it's underneath that. The master cylinder is the aluminum bar shaped thing that the brake reservoir sits on top of.
Old Dec 27, 2009 | 04:40 PM
dleccord's Avatar
you are correct! it is by the master cylinder.
do i need any special wrenches to pull it out?
Old Dec 27, 2009 | 04:41 PM
dleccord's Avatar
one more thing, you mentioned fuel pressure regulator. how do i diagnose if my regulator is bad or not?
Old Dec 28, 2009 | 03:03 PM
dleccord's Avatar
fuel pressure regulator anyone?
Old Dec 28, 2009 | 03:26 PM
VTECn83's Avatar
any CEL?
Old Dec 28, 2009 | 03:32 PM
dleccord's Avatar
none what so ever. just about twice a week on morning starts.
Sa.We25
Nov 2, 2013 02:43 AM
minigarcia09
Feb 18, 2013 09:42 AM
mag1000
Sep 19, 2006 07:41 PM
punkndisorderly84
Aug 1, 2005 09:12 AM
