Need some lube!!!!
Old Dec 25, 2009 | 04:57 PM
FearTheH's Avatar
Default Need some lube!!!!
Just wondering what the best lubricant for window tracks are. I've been debating whether the tracks need to be lubed or if the motors are going bad in my 99 EM1. Apparently its the rubber in the window tracks because when its wet the windows fly up and down like brand new. So anyone know what would be the best type of lube to put in there? Thanks in advance! And merry christmas or happy holidays!
Old Dec 25, 2009 | 06:49 PM
D Griff's Avatar
Default Re: Need some lube!!!!
I have manual windows and I put vaseline/petroleum jelly on the regulators when I replaced them, I don't think the rubber part gets lubricated, it would get on the window glass and make it look gross.
Old Dec 25, 2009 | 06:51 PM
itsnotfast's Avatar
Lube may help but the motor/regulator is likely the problem.
Old Dec 25, 2009 | 06:55 PM
bronx finest's Avatar
agreed, lube (and you should use WD40 or other silicone lubricant) will only delay the inevitable. which is you will either need to replace the window run channel or the regulator, or both.
Old Dec 25, 2009 | 06:59 PM
D Griff's Avatar
Replace the regulator before it ruins the channels! They cost $130 each or something outrageous like that from Honda.
Old Dec 25, 2009 | 07:05 PM
my channels, and regulator are both shot on my passenger side. i can't tell you how much i am NOT looking forward to fixing them come spring time.
Old Dec 25, 2009 | 07:20 PM
FearTheH's Avatar
Well my channels/tracks and my motor and regulator are fairly new on my driver side, and I've got a passenger side motor as well waiting for that one to go bad. The windows speed up when the tracks/channels are wet so I don't see any possible way of that being the regulator or motor. I had a problem for a while with my DS window coming out of track due to an alarm that was installed and wired to my interior light, well my courtesy light switch in my DS door jamb had a loose connection at one point and one night I started my car to let it warm up and shut my door...alarm never read the door as being opened so the auto lock kicked in and all of a sudden I have a shitty night. Used wedge and air splint from the trunk of our patrol car and in doing so, bent the top of the door/window frame thus putting it in a bind and eventually stripping the gears off of the motor. Honda told me to use white lithium grease but that was a major fail. And as far as getting stuff on the windows, they make this stuff for cleaning glass. I want some good, slick, yet resistant long lasting **** to put in the tracks..also going to do the regulator and moving parts accessible to the motor. Thanks for the input thus far
Old Dec 25, 2009 | 07:24 PM
thumper64's Avatar
Use silicone lube. Petroleum will just collect dirt...
Old Dec 25, 2009 | 07:29 PM
b18cKoupe's Avatar
winner
VEGAN_EG
Aug 23, 2009 07:29 AM
autoxthis
Oct 30, 2008 09:21 PM
jalexcar
Jul 19, 2008 07:14 AM
97teg415
May 5, 2005 11:23 AM
