katzenjammer84's 7th gen EM2::::CUSCO/KONI/RPF1/J'S RACING/WILWOOD/T1R
Old Dec 24, 2009 | 09:34 PM
katzenjammer84's Avatar
Default katzenjammer84's 7th gen EM2::::CUSCO/KONI/RPF1/J'S RACING/WILWOOD/T1R
I held off on this for a while, but the car is almost done now sans motor. Next couple months I'll be pulling the ecowheezer D17A2 out and rebuilding it from the ground up.
Shooting for 400WHP on C16 using a GT2871R with KPro's assistance.
I'll be updating this thread as I tear it apart and rebuild the innards.
Thanks for looking.
Currently weighing in: 2315 pounds
Stock Weight: 2597 pounds
Goal: 2275 pounds
Modifications
K+N OEM Replacement Filter
NGK V-Power Copper Plugs
Cusco Type OS Front Strut Brace
Koni Sport Yellow Dampers
Ground Control Sleeved Coilovers
Eibach ERS Springs (350F/475R)
T1R Inverted Tie-Rods
Eibach Pro Alignment Kit
Wilwood 12.19'' 4-piston Front BBK
J's Racing Adjustable Roll Center
Eibach 23mm Rear Swaybar (DC5)
Goodridge/Wilwood Stainless Brake Lines
Hotchkis Competition Endlinks Front + Rear
H+R TRAK+ 10mm Wheel Spacers (Front)
H+R TRAK+ 5mm Wheel Spacers (Rear)
ARP Extended Wheel Studs
16x7 Enkei RPF1s (Black)
205/50WR-16 Dunlop Direzza Sport Z1 Star Specs
BLOX Forged Aluminum Extended Lugnuts
20% Tint
WeatherTech Window Visors
Revo Short Shifter
Skunk2 440g Shift ****
Genuine Suede Door Inserts/Center Console
Cobra Imola S Front Bucket (Pass Side Delete)
Alpine IVA-W205 6.5-Inch In-Dash DVD Player
Honda OEM Foglights
"Type-R" style Front Lip
TSX 6000K Retrofits, Phillips Ballasts
Old Dec 24, 2009 | 10:01 PM
92sc61's Avatar
Default Re: katzenjammer84's 7th gen EM2::::CUSCO/KONI/RPF1/J'S RACING/WILWOOD/T1R
Looks good. You gonna be doing auto-x or time attack?
Old Dec 24, 2009 | 10:07 PM
Maybe for fun but not competitive. The peaky top end powerband wont work so hot for truly competitive autocross. Goal is an overall fun street car, nothing more.
Old Dec 24, 2009 | 10:16 PM
GetEfdupEH's Avatar
this should be good.
Old Dec 25, 2009 | 09:51 AM
sa3reghatch's Avatar
looking good
Old Dec 25, 2009 | 10:17 AM
SHG_James's Avatar
what was done to cut back on weight.
Old Dec 25, 2009 | 10:31 AM
gutted trunk
spare tire removal
rear seats removed
rear deck removed
carpets removed
kevlar composite shelled race bucket
passenger seat deleted
2-piece rotors with billet aluminum calipers
wheels (13.4 lbs each)
I say 2275 but I'll realistically go less than that. I want to get rid of all the sound deadening in the car, as well as pull the airbags, switch to forged wheels, F7 rear LCAs (3lbs of unsprung weight) and eventually weld in an LX or DX roof to rid myself of the moonroof assembly (50 lbs) plus all the added structural bracing in the roof to support it.
The roof sounds a bit overkill, but it really isn't. 50 pounds is a lot, especially when it sits so high up in the chassis like it does.
Old Dec 25, 2009 | 10:53 AM
SHG_James's Avatar
how much does the rear seat (upper the bottom combined) weigh. should get the car on a scale.
Old Dec 25, 2009 | 02:02 PM
The rear seat weighs quite a bit. The bottom cushion doesn't weigh much as it's obviously foam, but the rear seatback does because it's hinged to fold. I'd say 35 pounds or so, the entire assembly.
Old Dec 25, 2009 | 02:33 PM
Ho ho ho, Wiseco 8.8:1 75mm bore pistons ordered with Christmas funds.
Old Dec 25, 2009 | 02:37 PM
Chef Andre's Avatar
HT's TOP CHEF
Nice looking em2!!!!
Old Dec 25, 2009 | 04:49 PM
92sc61's Avatar
But why waste the time cutting all that weight if your not gonna race at all? Or are you street racing?
Old Dec 25, 2009 | 04:53 PM
Because less weight makes for better responses, which equates to more fun.
This holds true for handling, braking and acceleration.
And no, I'm 25 years old I won't be street racing.
Old Dec 27, 2009 | 02:23 PM
Crower rods ordered this evening.
Old Dec 27, 2009 | 10:52 PM
racing_reject_001's Avatar
saw this car on the kank cruise in the fall very nice!
Old Jan 1, 2010 | 01:14 PM
Couple lost pictures.
Old Jan 28, 2010 | 09:56 AM
*StevieG*'s Avatar
check out ephatch, theres a carbon fiber sunroof plug! this may be easier, but a little more pricey, for your sunroof prob, clean car btw, im a fan of function...... i bet its a fun sprinter to, i know my em2 loves the hills in central pa.. hows the brakes, did you ever think or up grading the rears to discs? ive got brembo slotted and hawk pads with some super blue amazing difference...!!! enkeis.... what made you decide to go with 10mm up front, and five in the back, im running 16x8's enkeis and just ordered a 10mm for the rear, since im running 5mm all around
Old Jan 28, 2010 | 10:04 AM
DrZFiNeSt's Avatar
Love that EM2
Old Feb 7, 2010 | 04:53 PM
The sunroof plug would work, but the fact is there's still extra bracing in the EX roofs to accommodate the sunroof glass and motor. So while it'd be a partial solution, it wouldn't be complete. Not to mention the fact that a completely enclosed roof would provide better structural rigidity than just a plug.
The brakes are amazing, not only does it stop less but it shaved close to 30 pounds of unsprung weight off the car. Helped handling, acceleration and braking immensely. I plan on doing a rear disc swap once the rear drums need to be replaced (I'm at 86K, I assume around 100K they'll be due for replacement).
The larger front spacer is for mild understeer correction. I tried a set of 16x8's, I liked the feeling of the 16x7's far better. Better turn in and steering response, plus the limits felt identical. They do fill the wheel well out a bit better though.
I'll have a bunch of updated photos in the next 4-6 weeks, car is sitting in pieces in storage awaiting new parts.
I sold my stock interior so there's nothing but bare floor right now.
Old Feb 7, 2010 | 04:55 PM
Originally Posted by DrZFiNeSt
Love that EM2
Thanks
Old Feb 7, 2010 | 05:04 PM
1.5Slowmatic's Avatar
if your saving weight why are you switching to rear discs?
Old Feb 7, 2010 | 05:15 PM
The weight gain is negligible. My main concern with the drums is that they are fade prone.
Old Feb 7, 2010 | 05:17 PM
Squidette's Avatar
subscribed.
Old Feb 8, 2010 | 11:57 PM
J.M.'s Avatar
Originally Posted by Squidette
subscribed.
+1
Old Feb 9, 2010 | 12:23 PM
JamesL's Avatar
gutted trunk
spare tire removal
rear seats removed
rear deck removed
carpets removed
Really? That's it? I see your car is an EX like mine.
Ive done all of the above, including aftermarket steering wheel/airbag delete, removed radio/deck and all the speakers... we have the same brakes and suspension setup. We both still have a sunroof. Im running 11.5lbs SSR Comps/Type-Cs... and my exhaust dumps after the driver's seat under the car...
The last time I weighed it, it came in around 2430lbs(although I have no idea how much gas was in the tank). Im failing to see where the 115lbs+ comes from
Edit: lololol... nevermind. I have an Autopower rollbar. I didn't think it weighed more than 80lbs, though. I need to get my car back on the scales.
