decel check engine light
Old Dec 24, 2009 | 07:28 PM
mitchchizo22's Avatar
Default decel check engine light
when i decel in gear the check engine light will come on.. when i turn the car off and back on its gone.. and suggestions
Old Dec 24, 2009 | 10:43 PM
placid888's Avatar
Default Re: decel check engine light
get the code first
Old Dec 25, 2009 | 09:40 AM
KNooBz's Avatar
mine does that too im obd0 it only comes on when i decel in gear and the rpms get around 2000
never checked the code though so im interested to see this
Old Dec 25, 2009 | 10:02 AM
dmeconitas's Avatar
If you peel back the carpet and look at the ecu you can count the blinking lights and retrieve the code.
Old Dec 29, 2009 | 11:58 AM
KNooBz's Avatar
o cool same way as my nissan was thanks
Old Dec 29, 2009 | 12:12 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
If it resets when you turn the key off,
Then usually the code will be for an O2 sensor..
Possibly the sensor is bad or it is running too rich...
Old Dec 29, 2009 | 12:19 PM
thanks alot for the advice guys
Old Dec 29, 2009 | 12:32 PM
89s1's Avatar
Does your speedo work?
My speed sensor is toast, so my speedo doesn't work, and it will only give me the CEL after a bit of off throttle deceleration in gear. Not sure why, but if I never engine brake, the CEL never comes on regardless of how far I drive the car.
oilspot
Feb 24, 2009 10:16 AM
E-AT_me
Jul 15, 2002 08:43 PM
Yellow Dragon
Aug 5, 2001 01:04 PM
