starting problems Help please
Old Dec 24, 2009 | 06:34 PM
melissashelton1's Avatar
Default starting problems Help please
Help please my car will not start. At first it would click once nothing keep doing it 4-5th time it would start. It would work for a couple days then same crap again. Now it will not start at all no click nothing. Thinking it was the starter i replaced it nope not it so I put the old one back on ( of course I tested it before putting back on). Not the battery test that first. What would cause this.
Old Dec 24, 2009 | 06:38 PM
civic_r87111's Avatar
Default Re: starting problems Help please
Blown fuses, bad ground (rusty or corroded), or corroded battery terminals maybe
Old Dec 24, 2009 | 06:41 PM
I wish it was that easy all fuses are good unless I missed one that is hidden. Battery is good cable clean and tight
Old Dec 24, 2009 | 06:47 PM
Former User's Avatar
The starter motor may be bad. Does it crank if you wire power directly to the starter solenoid?
Old Dec 24, 2009 | 06:53 PM
I bought a new starter thinking that was the problem didnt work so I test the old one with jumper cables works fine
Old Dec 24, 2009 | 06:54 PM
So u had the OEM starter tested and it worked perfectly? Maybe something in the ignition switch, I've had that problem b4.
Old Dec 24, 2009 | 06:57 PM
correct! what do you think about clutch switch ?????????
Old Dec 24, 2009 | 06:58 PM
Safety starter switch on clutch pedal?
G3 ground wire between the engine and transmission?
Ignition switch (as mentioned)?
Do you have a multimeter or test light? This would quickly pinpoint the problem. For example, do both starter wires get battery voltage?
Old Dec 24, 2009 | 06:59 PM
Could b the clutch safety switch and that is easy to bypass. Have to do this for remote start on manual trans cars
Old Dec 24, 2009 | 07:04 PM
I have a test light and I checked the one wire to starter and it lite up. How do I check the rest. I am a chic so full detail please I am car savvy but it takes me a minute
Old Dec 24, 2009 | 07:05 PM
one problem I can see it on the clutch but cant get to it any easy ways
Old Dec 24, 2009 | 07:10 PM
The large gauge wire is the one that is hot all the time and the other is the signal from the ignition switch. If u hook up ur test light to the smaller gauge wire it should light up when u turn the ignition switch to the start position. As for the clutch safety switch plugs, there is no easy way, if u have small hands and a flexible arm, just reach up in there and unplug them. U'll get scratched and scraped most likely.
Old Dec 24, 2009 | 07:47 PM
Correct. Follow these instructions. Touch one probe of the test light to a starter wire terminal and the other probe to the negative battery terminal or a metallic area of the body frame. If the small wire solenoid terminal does not get battery voltage, then check or jump the clutch safety switch. If the switch is fine, then next focus on the ignition switch.
D7KWagon
Aug 8, 2014 02:57 AM
etb75
Honda Civic (2001 - 2005)
Sep 29, 2013 01:29 PM
PuiPui
May 5, 2005 03:27 PM
Si1enzio
Jun 11, 2004 12:51 AM
